Ba Xr6T Modding Help
Featured Replies
#1
Hey guys, I've owned my falcon for 6 months or so now and I'm looking to stat modding.Curious as to which will benefit me most. It does already have a 3.5 inch cat exhaust system and an ss intake. Where should I go from here? Thanks in advance.
#2
Fuel pump, injectors, tune. And a better intercooler if funds permit.
#3
I've just done the following to my ba this week:
•valve springs
•injectors 60lb
•4" dump pipe
•hi flow cat (100 cell)
•bigger intercooler
Plus a tune running 10psi got it to 265rwkw
Definitely recommend the valve springs because they're know to fail in the ba and it's just peace of mind knowing it shouldn't be an issue anymore.
Injectors, not sure where the stock ones max out at power wise.
Dump and cat was just because I could. Saved a retune later on.
Intercooler was already done on the car when I got it.
#4
Sounds low ^^
#5
For 10 psi maybe about right with no fuel pump upgrade or actuator? Maybe the tuner thought that was enough with what was there?
Edited by BRK
#6
Injectors I bought turned out to be not so good so they're the limiting factor. That's all the tuner was willing to push out of it with them
#7
60lb are good for mid 300, if no I tank pump then I understand
#8
Yeah that I agree with. Just the ones I have aren't so good. They didn't scale well when tuned. Tuner said it would push more with better quality injectors
#9
And yeah the fuel pump is still stock too
#10
Ahh fair enough. Should just get them rebuild and match flowed
Recently Browsing 0
