  • Member For: 14y 10m 26d
Posted
Hi ,
I just brought a set of dba 5000 rotors for my f6 typhoon but not quite sure on brake pads what type I need it's just a street car had a chat with the man from race brakes Sydney he said the $150 ones might squeak is it worth buying the $300 ones
These were the street,race ones for 300 can someone give me some brands or advice if u can any help would be great thanks boys
  • Replies 25
  • Legacy Donating Member
  • Member For: 15y 2m 12d
Posted
I use qfm hpx, they are great but dont come with any noise suppression so I chamfered them myself. Havent sqeaked yet. $60 ish.
  • Carnage on the Garage Floor
  • Member For: 16y 4m 28d
Posted
+1 for QFM HPX. I chamfered the fronts but not the rears. No squeal. Very happy with them. Seem to get better with heat. Cost me $150 for the set - global stock them.
  • Member For: 21y 8m 24d
Posted
If you have a BA with the Blue FPV brakes then:
The Ford Factory pads are great with the DBA5000's. There is no squeaking. The brakes stay immediate, hard, stong and perfectly linear at all times no matter how hard you push on or how cold the brakes.
I tried the Ferodo DS2000's and found that that had a very impressive and immediate bite but:
  • ultimate Fc was considerably lower that the Factory Pads. They just don't have the same braking power as the Factory Pads. This was really annoying and a big let down.
  • the pads had noticable give, which like vague steering is steering is just a pain
DBA are now selling it seems the new Ferodo Performance line of pads, which are made in Italy. The DBA and the UK Ferodo sight have this graph
http://www.dba.com.au/products/ds-performance-pads/
that indicates the Fc goes from say 5.3 to just over 6.0 as the brakes heat up.
If the data is correct then this is simply amazing braking power for a road car. It is out there.
It is worth noting however that the data does indicate is how the pads go at temperarure at less that 100C as this is critical for road car performance. The sub 100C performance would need to be confirmed with Ferodo, or, with existing users of the pads.
Posted
I be reading a bit about hawk ceramic race pads any info would be unreal by the way thanks boys for all the helpful advice
  • Member For: 14y 8m 15d
Posted
Would you recommend qfm hpx for 6 pot brembo front and 4 pot rear? I have trouble sqeaking at the moment, so do you mean just chamfer the square edge of the pads? If so, how big chamfer?
F6-E, 6 & 4 Pot Brembos
DBA 4000XS Cross Drilled
Posted
^^^ chamfer on the leading and trailing edges should do it. That's all I did on my HPX pads and they're fine. Also, use a bit of brake pad lube on the piston faces before installing the pads.
Posted
Ive been told to chamfer thusly, Agree??
what brand and type are the stock pads?
