PCW Legacy Donating Member 181 Member For: 18y 7m 4d Gender: Male Location: Melbourne Posted 19/08/12 01:22 AM Posted 19/08/12 01:22 AM Hi Guys,I need to tap some power for my UHF and just wondering where the eassiest place would be.I have had a look around the fuse box area but thought there may be an eassier spot near the centre console. (doesnt need to be on all the time just accesories)Cheers,Pete
Paulie2256 Legacy Donating Member 7,441 Member For: 17y 10m 14d Gender: Male Location: SE Melbourne Posted 19/08/12 02:14 AM Posted 19/08/12 02:14 AM (edited) CB needs to go straight to the battery with an inline fuse on pos and neg wires. Don't piggy back off anything.You can then hook a relay up to a switched source and hook it up to the pos between the CB and battery.That way it will turn on and off with the key. Edited 19/08/12 02:17 AM by Paulie2256 1
PCW Legacy Donating Member 181 Member For: 18y 7m 4d Gender: Male Location: Melbourne Posted 19/08/12 11:30 AM Author Posted 19/08/12 11:30 AM Thanks Paulie, much appreciated.Pete
Paulie2256 Legacy Donating Member 7,441 Member For: 17y 10m 14d Gender: Male Location: SE Melbourne Posted 19/08/12 11:59 AM Posted 19/08/12 11:59 AM No problem mate. Will make it easier for you. There is a rubber grommet you can run the cables though next to the brake master cylinder. Usually your clutch master will sit there if manual. You can run the pos and neg wires though that. Then cable tie a relay above the pedals somewhere and run the switched source from the fuse box under the steering wheel. You can use a multimeter to find a switched source and just jam the wire in with the fuse from behind.
