July 28, 201214 yr #1 hey guys I know use have heard it all before but my check engine light has popped up in my bf phoonI just recently changed my o2 sensors about 10000ks ago...would it help if I reflash it?help and thanks in advance
July 28, 201214 yr #3 Author p1131 code is that my o2 sensors?running lean.... Edited July 28, 201214 yr by HSV ETR
July 28, 201214 yr #5 Author mmmmm ok well I deleted the code from the flash tuner and went for a drive and the engine light hasnt come back up yet....any idea what it might be if its not the o2???should it be something to be worried about?
July 28, 201214 yr #6 Those error codes P1131 and P1132 will be your O2 sensor, low voltage signal or something like that. New O2 sensor, reset ECU and she's done (Quoted from other Ford forum)
July 28, 201214 yr #7 Author well I havent driven my car for about 3 weeks and my battery is nearly flat would that have something to do with it?
July 28, 201214 yr #8 Well, wait and see if it comes back.If it does, sounds like the O2 sensor is suspect.Don't think the long spell without driving and flat battery would be the cause. My car gets driven infrequently, and have had a flatish battery several times, but never any codes as a result. Edited July 28, 201214 yr by Ninka
July 29, 201214 yr #9 o2's get replaced frequently for no reason except they are doing their intended job, reporting what is happening, yes they do fail from time to time and need to be replaced, but if there is other issues with the car car, replacing them will not fix the problem although it may appear that way for a while
July 29, 201214 yr #10 Author ok soo ive driven over 100ks since deleted the code off my flash tuner and the engine light hasnt come up yet, if it does ill buy some new o2'sill be sending my car to get some work done next week so ill get my tuner to keep an eye on it....new to this forum and very helpful so far, love it thanks guys!
