rbjet Skid Machine Donating Members 1,640 Member For: 13y 11m 13d Gender: Male Posted 12/07/12 02:16 AM Share Posted 12/07/12 02:16 AM It's not that simple in a Falcon I'm afraid. If you want to be able to run different boost settings you need 2 separate tunes in your Xcal. Link to comment https://www.fordxr6turbo.com/forum/topic/80917-need-help-ba-mk-ii-mods/page/2/#findComment-1266218 Share on other sites More sharing options...
Rydeit Member 327 Member For: 12y 9m 26d Gender: Male Location: Adelaide S.A Posted 12/07/12 07:09 AM Author Share Posted 12/07/12 07:09 AM Never knew that. Thanks for the info. Even with the sct tuner can't run 2 different boost settings? Link to comment https://www.fordxr6turbo.com/forum/topic/80917-need-help-ba-mk-ii-mods/page/2/#findComment-1266367 Share on other sites More sharing options...
PookeyMaster Donating Members 1,531 Member For: 14y 4m 17d Gender: Male Location: Parramatta, NSW Posted 12/07/12 02:49 PM Share Posted 12/07/12 02:49 PM 2 different boost settings in seperate tunes is what you have to do. The Falcon's boost is electronically controlled so if you increase the boost, the ECU will go in to limp mode when it exceeds the thresholds that have been set. If you set a high threshold and run a low boost (say you set the threshold to 20psi and your controller did 15psi and 20psi) you get problems because at WOT the ECU in essence keeps trying to add more boost. It just doesn't work with a boost controller. Link to comment https://www.fordxr6turbo.com/forum/topic/80917-need-help-ba-mk-ii-mods/page/2/#findComment-1266606 Share on other sites More sharing options...
