judgee New Member 23 Member For: 14y 6m 16d Posted 01/05/12 02:36 AM Share Posted 01/05/12 02:36 AM Hi guys have a suspicion that my 2005 BA MKII XR6T is overboosting and going into limp mode.The car is stock besides a K&N Filter and Snorkel + a FPV F6 cooler. Has run fine with these mods and nothing has changed but last night it was a little colder than normal up here in the NT and When I gave it some it would build boost and then hit some kind of cut out around 3-4000RPM. Happens every time now. Car did have a 1/4 tank at the time but have since filled it up with BP Ultimate and still does the same thing.Any ideas on what to check? Link to comment https://www.fordxr6turbo.com/forum/topic/79964-limp-mode-under-acceleration/ Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 13d Gender: Male Location: SE Melbourne Posted 01/05/12 02:36 AM Share Posted 01/05/12 02:36 AM The ODB-II code Link to comment https://www.fordxr6turbo.com/forum/topic/79964-limp-mode-under-acceleration/#findComment-1229921 Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 14y 9d Gender: Male Location: Victoria Posted 01/05/12 02:43 AM Share Posted 01/05/12 02:43 AM (edited) Could be the turbo actuator or....diff bushes.What Paulie said.. Edited 01/05/12 02:45 AM by _Velocity_ Link to comment https://www.fordxr6turbo.com/forum/topic/79964-limp-mode-under-acceleration/#findComment-1229929 Share on other sites More sharing options...
judgee New Member 23 Member For: 14y 6m 16d Posted 01/05/12 02:47 AM Author Share Posted 01/05/12 02:47 AM Righto I'll have to order one of those Kiwi Wifi things then or go to a tuner. Any suggestions for where to go up in Darwin. Link to comment https://www.fordxr6turbo.com/forum/topic/79964-limp-mode-under-acceleration/#findComment-1229933 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 13d Gender: Male Location: SE Melbourne Posted 01/05/12 02:50 AM Share Posted 01/05/12 02:50 AM don't you have an xcal? otherwise just get a ford dealer or your tuner to read the code (dealer will probably charge)There may not even be a code but tuner should tell you whatup anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/79964-limp-mode-under-acceleration/#findComment-1229937 Share on other sites More sharing options...
daztbo FLY-FPV Donating Members 474 Member For: 15y 9m 6d Gender: Male Location: Greensborough Vic Posted 01/05/12 02:51 AM Share Posted 01/05/12 02:51 AM Hmmm chech the vac hoses near the actuator and boost solenoid mine was over boosting one day cos I melted the rubber hose Link to comment https://www.fordxr6turbo.com/forum/topic/79964-limp-mode-under-acceleration/#findComment-1229939 Share on other sites More sharing options...
judgee New Member 23 Member For: 14y 6m 16d Posted 01/05/12 04:18 AM Author Share Posted 01/05/12 04:18 AM Checked all the hoses and were fine. Seems a bit better today but still breaking down at higher revs. I'd rather see a tuner than go to ford. Anyone know a tuner in Darwin Link to comment https://www.fordxr6turbo.com/forum/topic/79964-limp-mode-under-acceleration/#findComment-1229984 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 11d Gender: Male Location: Perth Posted 01/05/12 08:12 AM Share Posted 01/05/12 08:12 AM Has it had a set of plugs fitted at any time in living memory? Link to comment https://www.fordxr6turbo.com/forum/topic/79964-limp-mode-under-acceleration/#findComment-1230085 Share on other sites More sharing options...
judgee New Member 23 Member For: 14y 6m 16d Posted 01/05/12 09:28 AM Author Share Posted 01/05/12 09:28 AM Yes, Plugs replaced about 500km ago. Standard Ford plugs. Car only has 90,000km. Been driving it round before and I think it could be more of a spark issue as it boosts fine and once it hits around 3500RPM it backs off like something is holding it back. Pulls hard up until then though and if I load it up in a higher gear like 4th of 5th it runs perfect. it just seems to do it in 2nd and 3rd when it gets around 3500. Called Peckys Performance but cant get in for around a week or two. Link to comment https://www.fordxr6turbo.com/forum/topic/79964-limp-mode-under-acceleration/#findComment-1230164 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 6m Gender: Male Location: Muswellbrook,NSW Posted 01/05/12 10:18 AM Share Posted 01/05/12 10:18 AM coils! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/79964-limp-mode-under-acceleration/#findComment-1230181 Share on other sites More sharing options...
