  • Legacy Donating Member
  • Member For: 16y 2m 26d
Posted
Just got a phonecall from a mate his BF GT has a flat battery and he was going to use his trickle charger to charge the battery when he thought he should ask me first.
Never have I done myself but is it ok to have the battery in the car with the terminals connected and charge it ??? Cars been sittin gsince all ford day.
You info will help him out.
  • Replies 26
  • Member For: 20y 4m 14d
Posted
No!, he may cause damage to the altenator or ECU, disconnect a terminal first.
Posted
Thanks guys. wouldn't the alarm go off if he disconnects the one terminal?
  • Member For: 15y 3m 3d
Posted
I think you can get some chargers that are safe can't you? I'd never use a normal charger and do it but I had a trickle charger for my bike and it was designed to be wired up to the battery with a plug where you plug the charger in so all you do is plug the charger into the plug on the bike.
Posted
they are normally classed as battery maintainers, basically a low power charger, they charge when battery condition is down and the stop when a good charge is detected
  • Member For: 17y 10m 20d
Posted
In the case of the bike there could be a relay in the electrical system that isolates the battery when charger is connected. I know fire trucks are put on charge using a separate connector when sitting at the station but they also have a manual isolator.
Posted
I have 3 bikes (well 1 is really Bels) that are on the maintainer all the time, I did not fit or believe them to have anything special in the wiring
Posted (edited)
Awesome guys very informative and many thanks from him.
I know abit about these cars but I always get asked by mates with the same models as everybody knows how I am Ford through and through, amd know my Fords.
Edited by nick d
