April 21, 201214 yr #1 Sorry if this has been covered but I did a search and it wont allow "code" to be searched and other words drew a blank.I've had a12inch JL audio sub and kicker amp installed in my ba xr6t today and when I tried to turn the car on the radio said "code" on the icc screen. I tried it again and the radio played for about 30secs then turned off again.If I try and turn the car over to move it (as its blocking my parents drive) it just makes a clicking sound and wont kick over. I'm assuming the icc has enabled the immobiliser until I get the code but I cant find it and ford are closed till monday :banghead:Is there anyway to get the car going or somewhere I can get the code from?Thanks
April 21, 201214 yr #2 Try to disconnect your battery (both negative and positve) for 5 mins then connect again and see how you go.
April 21, 201214 yr #8 definatley sounds like a flat battery..happened to my bros ba when we fit his subs...
April 21, 201214 yr #9 Author Charger broke after few minutes cos someone left it out in the rain. :banghead: so I'll grab one off my mates tomorrow after work and give it a try. Thnks for all the help so far and I'll let you know how it goes
April 22, 201214 yr #10 the batt and charing system in these cars have little overhead for things like running stereos with the car off. so even doing a couple of 1 hr keyless plays with a tired batt will result in no start!if the recharge does work, check the 4 connectors under the icc if u had it out
