chiso92 Member 8 Member For: 14y 5m 6d Posted 20/04/12 10:28 PM Posted 20/04/12 10:28 PM hi there, iv just purchased my self an xr6t and just havin a few little issues1, when im givin it a bit of right foot on boost it will just seem to cut the power, I was thinking some sort of restricter but sometimes it does it at 3500 revs n sometimes it does it at 5000 revs valve springs have only just been done 2 mnths ago....2, this weird shutter ( iv only noticed it when the car cools down, as in if I drive somewhere then park it up for an hour the go for a drive it will do it again, only for 5-10 seconds) the car will stall if you dnt rev it, it seems like its not running on all cylinders.3, clunking in the diff, or something in the rear. when changing gears the clunking is very noticeable but iv seen receipts from not too long ago the diff having some warranty work done to it..any helpfull info would be greatcheers troy
PookeyMaster Legacy Donating Member 1,531 Member For: 15y 9m 8d Gender: Male Location: Parramatta, NSW Posted 22/04/12 11:20 AM Posted 22/04/12 11:20 AM The rear shudder could be the diff bushes have gone and need replacing.
geekatrons Member 60 Member For: 14y 5m 5d Posted 21/08/12 09:48 AM Posted 21/08/12 09:48 AM Hello- The issue with cutting out- I had an issue with my boost actuator- got replaced problem solved. As for the rear clunk it will more than likely be diff bushes- I will be getting mine done soon.
