11/10/11 07:08 AM11/10/11 07:08 AM #1 Noticed a puddle of clean water on the drivers side floor today after running the air cond for a half hour drive, its coming from under the centre consol and running down the tunnel to the floor, quite wet under the front of the centre consol,does anybody if there is there an air cond drain hose up under there somewhere? Thanks Edited 11/10/11 07:09 AM11/10/11 07:09 AM by hypnodoc
11/10/11 07:10 AM11/10/11 07:10 AM #2 Theres a drain tube under the car. It sits above the trans,towards the front of the tunnel.
11/10/11 07:39 AM11/10/11 07:39 AM #3 Yea its the condensation drain line that has most likely come off the air con system. It should be attached at the bottom of the air con radiator box.Just looked in my manual to get you a picture/drawing but they dont cover it apart from the fact its one of those oval type rubber grommets. Edited 11/10/11 07:47 AM11/10/11 07:47 AM by Wenier
11/10/11 08:51 AM11/10/11 08:51 AM #4 Author Thanks gents, looks like a bit of under dash fossiking to be done
