Snapper Legacy Donating Member 320 Member For: 15y 5m 11d Gender: Male Posted 03/10/11 05:31 AM Posted 03/10/11 05:31 AM So the rods are the weak link in the f6 interesting as there are a few in the low 400s with out rods
bluprinturbo Legacy Donating Member 605 Member For: 18y 4m 19d Gender: Male Location: brisbane Posted 03/10/11 06:28 AM Posted 03/10/11 06:28 AM the main factor in almost all of our bottom ends letting go is the rods, so yes they are the weak link. there are some ba's in the 400's without rods. give me one person who would recommend that. as for the pistons, here goes. from what im led to believe, acl was the manufacturer of pistons for ford and many other car companies for that matter. im pretty sure there policy was to use a forged piston for any engine producing 100 or more hp per litre which the f6 does. mahle have taken over the piston division of acl, so there it is, mahle forged pistons. acl or mahle are not just aftermarket. they do heaps of oem as well.the part number for rods is the same between fg xr6t/f6. I know that as I rang ford myself. they couldnt however tell me anything about the pistons. im happy to be proven wrong on it.on another note, it suprises me that rdp would remove the engine from their fg to do valve springs, head studs and oil pump gears but not replace the rods while it was out. doesnt make sense. I guess they want to find the limit of them and can obviously afford to do so.
45T-XR Legacy Donating Member 417 Member For: 19y 6m 24d Gender: Male Location: Gladstone, Queensland Posted 10/11/11 11:17 AM Posted 10/11/11 11:17 AM I cant be certain, but I think that was lees intention, to find out how tough these new engines are, Im assuming they couldnt get the headstuds in due to the back of the engine sitting under the wiper cowl, although its been ages since I had the rocker cover off and cant remember exactly how far the studs would be being between 5 and 6 there might be enough room though. As I think they just used the smaller head studs that keep the stock holes in the block. Could be wrong though
Mr_4.0 Member 1,096 Member For: 15y 8m 11d Posted 10/11/11 12:03 PM Posted 10/11/11 12:03 PM Ba-bf-fg all had different cams also I believe...
retro-xr6t Legacy Donating Member 95 Member For: 16y 8m 17d Gender: Male Posted 12/11/11 09:48 PM Posted 12/11/11 09:48 PM Bf has 8 degrees more lift on the exhaust side than the ba, inlet is the same.
djqc Member 291 Member For: 14y 11m 22d Posted 13/11/11 12:10 PM Posted 13/11/11 12:10 PM whats the max power been made on an fg xr6t unmolested block/head etc
XYZ Legacy Donating Member 1,171 Member For: 17y 13d Posted 13/11/11 12:35 PM Posted 13/11/11 12:35 PM whats the max power been made on an fg xr6t unmolested block/head etc I believe Rob from Monster Torque FG ute has run over 500rwkw on the totally standard motor (unopened) with upgraded turbo on E85...
djqc Member 291 Member For: 14y 11m 22d Posted 13/11/11 02:09 PM Posted 13/11/11 02:09 PM I believe Rob from Monster Torque FG ute has run over 500rwkw on the totally standard motor (unopened) with upgraded turbo on E85... Looks like the car is in good hands then
