04/09/11 03:51 PM04/09/11 03:51 PM #11 Author Aww yeah. Where does bleed off valve bleed to? Atmosphere? A dude named Dave. Does some drag cars. He uses ems computers.
04/09/11 10:53 PM04/09/11 10:53 PM #12 Drop you wastegate spring to 1/2 your intended boost pressure. Try you direct connection method as you have it now.You'll probably find the boost pressure will be two low and you'll need to reconnect the boost solenoid to get your boost level back up but you should get some control back. 40mm gate should be more than enough
04/09/11 10:59 PM04/09/11 10:59 PM #13 Author I had already changed spring and it didn't make a difference but I didn't try but solenoid back on. I'll try that thanks mate
04/09/11 11:09 PM04/09/11 11:09 PM #14 any pictures of your setup? Silly question but is the gate installed in the correct orientation?
04/09/11 11:17 PM04/09/11 11:17 PM #15 Author I'll have to put one up later. Only on my phone now so won't let me upload. The waste gate comes just before the turbo. It's welded onto the manifold right at the flange
