lach Member 83 Member For: 15y 10m 5d Gender: Male Location: Melbourne Posted 14/06/11 05:20 AM Posted 14/06/11 05:20 AM (edited) As the title says, has anyone removed the speaker panels?how did they come apart?Thanks. Edited 14/06/11 05:27 AM by lach
Rancidpunx Brisbanes Resident Detailer Legacy Donating Member 950 Member For: 17y 8m 16d Gender: Male Location: In my Cabin Outside Brisbane. Posted 14/06/11 06:19 AM Posted 14/06/11 06:19 AM Apart from one bolt, everything is just clipped in. First pop of the seat beltbolt cover and then remove the bolt itself. Removing the seatbelt just makes access easier, taking the seats out also really helps and for a 3minute job well worth it. The plastic covers around the seat mounts just pull off, although some force is needed. Finally pull the door seal away from the bodywork, then just pull the rear panel towards you. You can also remove all the scuff panels from the bottom of the door opening as well to make life easier. Use a watchmakers screwdriver to pop out the long thin cover and then remove the 2 (maybe 3) screws.Fairly easy.
Dagabond Bored Member Administrator 35,722 Member For: 23y 10m 22d Gender: Male Location: Dé·jà vu Posted 14/06/11 08:11 AM Posted 14/06/11 08:11 AM Ute or Sedan...
lach Member 83 Member For: 15y 10m 5d Gender: Male Location: Melbourne Posted 14/06/11 09:21 AM Author Posted 14/06/11 09:21 AM (edited) Ute or Sedan...UTE,Rancid, do you mean the front speakers?I just want to take off the back section, right behind the seats, on the back wall and the side parts right near the speakers.do I have to pull off the whole driver side and passenger side to access the rear??Thanks for the help. Edited 14/06/11 09:22 AM by lach
lach Member 83 Member For: 15y 10m 5d Gender: Male Location: Melbourne Posted 23/06/11 11:48 PM Author Posted 23/06/11 11:48 PM any suggestions??
