30/03/11 11:38 AM30/03/11 11:38 AM #1 Just ordered my ute. White with 0 options. Am going after-market for everything except KWs (I like warranty). Suspension is sorted through Quadrant (Bilstein kit), now its brakes. I like the 6 spot brembo option available so will get that with some DBA rotors but what about the rear? Who makes a matching 4 or even 2 spot rear kit for the utes? I see they are an option on the FoolishlyPricedVehicles but cant find a kit after-market.Car will be taken to Phillip Island & Sandown for a few track days so I plan to change pads & the day before.Any body (sponsors) have any ideas?
30/03/11 11:54 AM30/03/11 11:54 AM #2 I've just got the 6p Brembo kit on the front & it's plenty good enoughto make your eyes fall out when you stand on the pedal. I wouldn't worry about the rear, just paint the calipers to match.
31/03/11 11:06 PM31/03/11 11:06 PM #3 Just ordered my ute. White with 0 options. Am going after-market for everything except KWs (I like warranty). Suspension is sorted through Quadrant (Bilstein kit), now its brakes. I like the 6 spot brembo option available so will get that with some DBA rotors but what about the rear? Who makes a matching 4 or even 2 spot rear kit for the utes? I see they are an option on the FoolishlyPricedVehicles but cant find a kit after-market.Car will be taken to Phillip Island & Sandown for a few track days so I plan to change pads & the day before.Any body (sponsors) have any ideas?Be careful with your rim selection. Ford FG 18 and 19" dont clear Brembos. I use my FG at the circuit and found the 4 pots to be adequate for me anyway with circuit pads.Had to upgrade my rears as some fgxr6t only cames with a solid rear disc (303mm I think), not twin ventilated. Check to see what you have. I was lucky to get some bigger calipers rear ventilated 328mm rotors (on Territory and FPV's. Maybe search for details on rear territory upgrade.
31/03/11 11:43 PM31/03/11 11:43 PM #4 They all only come with the non-ventilated unless you get a brake upgrade.The only time they had the vented on the T's was the BF mkI, they removed them for cost cutting in the Mk II. Good upgrade to do...
01/04/11 05:04 AM01/04/11 05:04 AM #6 Pretty sure the rear of my BF2 is vented.Maybe there were some rouge ones, however they 'officially' stopped with Mk II...
01/04/11 09:35 AM01/04/11 09:35 AM #7 Author Maybe there were some rouge ones, however they 'officially' stopped with Mk II...So is it a bolt on upgrade? No magic adaptors or anything required?
