My_XR6_Turbo Member 282 Member For: 20y 10m Posted 23/03/11 02:26 AM Share Posted 23/03/11 02:26 AM OK guys, I think my turbo is stuffed. I was driving along and heard a funny grinding noise on boost. I have checked the turbo and there is no play up or down nor in and out but if I spin the turbo you can hear the bearings grind. So what are my options? Do I purchase a new turbo? Get mine rebuilt? How much am I looking at? I live in Melbourne so who would you recommend to do the rebuild? Can I take the turbo off the car and still drive it?Are there any step by step instructions on how to remove the turbo?Thanks guys.Will this fit?http://cgi.ebay.com/...=item230f518e19 Link to comment https://www.fordxr6turbo.com/forum/topic/73933-stuffed-turbo/ Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 9m 27d Gender: Male Location: Newcastle Posted 23/03/11 09:04 AM Share Posted 23/03/11 09:04 AM (edited) You shouldn't try to drive your car without the turbo and it would take the manufacture of an exhaust dump modification to be close to successful. I'd suggest removing it and getting it rebuilt by a reputable company. I'm not sure who is the suggested places in Vic but in NSW it's GCG or MTQ in Sydney. The cost will vary depending on what is damaged and what needs to be done. I've seen quotes for between $800 and $1700.The turbo you have found on ebay looks to need an external wastegate so no it's not suitable to bolt straight in.I'd look to replace your oil feed line also with an inline Earls filter or the like.Benny Edited 23/03/11 09:08 AM by Benny Link to comment https://www.fordxr6turbo.com/forum/topic/73933-stuffed-turbo/#findComment-1091315 Share on other sites More sharing options...
azz Bronze Donating Members 37 Member For: 14y 2m 15d Gender: Male Location: up in the clouds Posted 26/03/11 10:40 AM Share Posted 26/03/11 10:40 AM (edited) I'm having mine rebuilt. All new feed line without filter. Would rather "dirty" oil in bearing than none at all. around $2g. 2 day job. Nizpro Bayswater. Edited 26/03/11 10:44 AM by azz Link to comment https://www.fordxr6turbo.com/forum/topic/73933-stuffed-turbo/#findComment-1092112 Share on other sites More sharing options...
r32dan Donating Members 62 Member For: 14y 6m 5d Gender: Male Location: Gold Coast Posted 27/03/11 07:02 AM Share Posted 27/03/11 07:02 AM make sure you ring around and get lots qoutes as prices can vary alot, as with all automotive feilds. and take Azz's advice and make sure you piss off the standard oil line filter.... Link to comment https://www.fordxr6turbo.com/forum/topic/73933-stuffed-turbo/#findComment-1092259 Share on other sites More sharing options...
