Bad Apples Donating Members 110 Member For: 19y 9m 11d Gender: Male Posted 07/03/11 11:48 AM Share Posted 07/03/11 11:48 AM Hi All.I currently run BA camshafts in a 698 atomic engine.I'd like to ask people experiences with the larger camshafts for a daily driver, taking into account idle torque (for taking off discreetly at 6:30 am), and fuel economy.I expect the BF cams give a significant improvement in power (based on the specs, and tuning results), but good economy (given they are factory fitted).What about the next size up? -I.e. atomic stage 3 and Crowcams #3231393?Then there are crowcams 3232562, which is larger, but aimed at NA, so may aid off boost performance...The next size up is atomic stage 4. Do they produce usable torque near idle?There is an opportunity to fit larger camshafts in the near future, but retain standard exhaust manifold and turbo. The exhaust is CES 3.5" turbo back. The intake is process west race airbox. nizpro 'original' intercooler and process west throttle body re-location.Only 1 round of (engine) upgrades to go, .. GTX 4294 (1.01 turbine A/R) on a 6boost style manifold - so bear in mind I'd like the final configuration to suit, as a daily driver. Other relavent information is that being a BA I have the BA ecu, I do not expect this to be a limitation but I understand the newer ones are better...Please share your experiences Cheers,Chris. Link to comment https://www.fordxr6turbo.com/forum/topic/73675-cam-size-and-usability/ Share on other sites More sharing options...
Bad Apples Donating Members 110 Member For: 19y 9m 11d Gender: Male Posted 09/03/11 03:53 AM Author Share Posted 09/03/11 03:53 AM Bump?Is there something more I should add? Link to comment https://www.fordxr6turbo.com/forum/topic/73675-cam-size-and-usability/#findComment-1087415 Share on other sites More sharing options...
dule Donating Members 1,180 Member For: 18y 17d Gender: Male Location: Sydney Posted 09/03/11 05:15 AM Share Posted 09/03/11 05:15 AM From what I see here not many people change cam shafts at all, apparently there is no need so not many would have experience with larger ones... Link to comment https://www.fordxr6turbo.com/forum/topic/73675-cam-size-and-usability/#findComment-1087446 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 3m 14d Posted 09/03/11 07:58 AM Share Posted 09/03/11 07:58 AM I think bf cams are plenty big enough. U don't get that much gain with these motors with boost and big cams. The outlay and extra fuel consumption isn't worth the small gain. Link to comment https://www.fordxr6turbo.com/forum/topic/73675-cam-size-and-usability/#findComment-1087495 Share on other sites More sharing options...
raz1911 Member 110 Member For: 11y 11m 19d Gender: Male Posted 12/02/15 09:54 AM Share Posted 12/02/15 09:54 AM Are BF turbo cams the same as NA cams?I know this thread is old but there isnt much point in making a new one. I have tried to look some say yes some say no? Link to comment https://www.fordxr6turbo.com/forum/topic/73675-cam-size-and-usability/#findComment-1529704 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 2d Gender: Male Location: Adelaide Posted 12/02/15 10:18 AM Share Posted 12/02/15 10:18 AM No 1 Link to comment https://www.fordxr6turbo.com/forum/topic/73675-cam-size-and-usability/#findComment-1529712 Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 8m 15d Posted 12/02/15 08:25 PM Share Posted 12/02/15 08:25 PM Factory FG cams seem to be desirable in earlier barras.. Link to comment https://www.fordxr6turbo.com/forum/topic/73675-cam-size-and-usability/#findComment-1529774 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 1m 1d Gender: Male Location: Liverpool Posted 12/02/15 10:04 PM Share Posted 12/02/15 10:04 PM Anyone know if all the FG cams are the same? NA, xr6t and F6? Link to comment https://www.fordxr6turbo.com/forum/topic/73675-cam-size-and-usability/#findComment-1529780 Share on other sites More sharing options...
"Captain Retard" Member 1,417 Member For: 11y 1d Gender: Male Location: Shellharbour NSW Posted 12/02/15 10:16 PM Share Posted 12/02/15 10:16 PM Once again.......does anybody know the specs for the different camshafts??????I can't understand why people talk about cams without at least having some idea of basic specs.But I'll take a wild guess and presume that the only difference between Turbo and NA would probably be that the Turbo cams have wider lobe centres. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/73675-cam-size-and-usability/#findComment-1529782 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 1m 1d Gender: Male Location: Liverpool Posted 12/02/15 10:36 PM Share Posted 12/02/15 10:36 PM I'm well aware of cam grinds and their effects, mainly just asking if the xr6 and f6 are the same... And I'm not sure if Lobe separation can be adjusted in the tune between NA and Turbo Link to comment https://www.fordxr6turbo.com/forum/topic/73675-cam-size-and-usability/#findComment-1529786 Share on other sites More sharing options...
