  • Legacy Donating Member
  • Member For: 19y 6m 7d
Posted
my front calipers are clamping up on rotors and are not releasing car has only done 60,000 klm have tryed new m/cyl but I think it is the calipers if you bleed the brake fluid you can move the wheels only have std calipers with dba 4000 rotors, that I have burnt to a crisp now, has any one had this problem before?
  • Moar Powar Babeh
  • Member For: 21y 15d
Posted
Brake booster will be dicked. Atmo valve will be leaking and allowing the the booster too gradually pressurize the brakes system
Posted
the back brakes are not locking up only the front two when the mecanic had it on the hoist need some brembos lol
  • Moar Powar Babeh
Posted
The fronts get more pressure than the rear so they will lock before the rears.
Take the master cyl off, start the car and i bet the actuator rod in the brake booster moves out
Posted
should I change the booster over to the fpv one as its bigger for the brembos?
  • Moar Powar Babeh
Posted
booster is the same, master cylinder is bigger on FPV equipped brembo's
Posted
thanks for that will track one down now to get the beast back on the road.
Posted
mecanic rung this morning and said the four front caliper pistons were siezed due to grease breaking down pretty crap as ive only done 60,ooo klm
