DavoWA Proud Team Blueprint member Member 286 Member For: 22y 1m 3d Location: Perth Posted 08/05/03 01:57 AM Share Posted 08/05/03 01:57 AM Thanks 1axr and exr6.I think that this is probably the first, safest and least expensive positive performance change that can be made to any car.My XJS (yes, a mobile heat exchanger!)gained approx 12 rear wheel hp just from this. Link to comment https://www.fordxr6turbo.com/forum/topic/733-aftermarket-air-filters/page/6/#findComment-21659 Share on other sites More sharing options...
Guest Mr Walker Guests Posted 08/05/03 02:40 AM Share Posted 08/05/03 02:40 AM Davo,Is it safe? I remember alot of talk about K&N Filters flowing better but not filtering as well as standard ones. What's the go? Link to comment https://www.fordxr6turbo.com/forum/topic/733-aftermarket-air-filters/page/6/#findComment-21673 Share on other sites More sharing options...
Cam Member 397 Member For: 22y 3m 18d Location: Brisbane Posted 08/05/03 02:50 AM Share Posted 08/05/03 02:50 AM Does the filter equate to a genuine performace gain or does the ECU prevent any actual gain?? Link to comment https://www.fordxr6turbo.com/forum/topic/733-aftermarket-air-filters/page/6/#findComment-21680 Share on other sites More sharing options...
Guest exr6 Guests Posted 08/05/03 04:32 AM Share Posted 08/05/03 04:32 AM Our dyno day proved a big increase with the BMC filter.My XR6T auto - 192Kw rear wheels (stock)XR6T auto with BMC filter - 202Kw rear wheelsThe ECU seems to allow this no with problems Link to comment https://www.fordxr6turbo.com/forum/topic/733-aftermarket-air-filters/page/6/#findComment-21713 Share on other sites More sharing options...
DavoWA Proud Team Blueprint member Member 286 Member For: 22y 1m 3d Location: Perth Posted 08/05/03 11:00 AM Share Posted 08/05/03 11:00 AM Mr Walker,Filtration is another good subject, but it revolves around the number and sizes of the particles that the filter traps.Paper (most standard elements) "clogs" up more quickly as the particles build up on each other and block the filter media. Filters are designed to block a certain amount of particles above a certain size, can also be described as the Beta ratio. I need to find out more.As far as the ECU working, if the ECU cannot detect any faults, then it will simply adjust the signals according to the information it receives. In other words, if it "sees" more air and the temp is OK and the O2 sensor is OK, then it will simply give the engine more fuel. More air + more fuel = bigger bang = more grunt.This is of course provided that the numbers it "sees" are within its' operating tables. Bit like the MAP sensors on some of the older N/A engines. If you put a blower on them, the MAP sensor wouldn't recognise the positive boost, so the engine just ran lean cause it couldn't get more fuel.I'm not a computer whiz, but I think that's what happens if you just try o overboost the stock setup, hence the need for different computer bits.There must be someone who can explain it better than this? Link to comment https://www.fordxr6turbo.com/forum/topic/733-aftermarket-air-filters/page/6/#findComment-21826 Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 22y 26d Gender: Male Location: stanthorpe wine capital of qld. Posted 08/05/03 07:28 PM Share Posted 08/05/03 07:28 PM DAVO YOU EXPLAINED IT JUST RIGHT THAT IS BASICLY WHAT HAPPENS. that's WHY WHEN YOU FIT A LARGER COLD AIR INDUCTION UNIT ON THEY GO HARDER AS WELL.(SHOULD HAVE MY NEW COLD AIR INDUCTION ON NEXT WEEK ) WILL POST RESULTES WHEN FITTED) Link to comment https://www.fordxr6turbo.com/forum/topic/733-aftermarket-air-filters/page/6/#findComment-21863 Share on other sites More sharing options...
Guest atessa Guests Posted 16/07/03 01:53 AM Share Posted 16/07/03 01:53 AM SUN-EX PERFORMANCE : BA 4.0 TURBO BMC REPLACEMENT FILTER $165Copy from bmc website http://www.bmcairfilters.com/index.asp?IDLang=0 PERFORMANCEBMC air filters are designed and produced to ensure a higher air flow than original paper filters. In F1, for example, BMC cotton filters minimize the loss of air flow pressure passing through the air filter; this way ensures the best conditions for full exploitation of maximum power. Therefore the benefits of replacing the original paper filter with BMC cotton air filter, produced using the same technology and materials as the F1 air filters, are evident. DESIGN AND MATERIALSQualified engineers using advanced software and expert technicians using the latest technologies produce BMC air filters. An F1 filter must be very light, must be made of the best raw materials and must improve performance. For this reason we use only alloy mesh with epoxy coating to ensure protection from petrol fumes and from oxidization due to the humidity of the air. The filtering material is composed of a special cotton gauze soaked with low-viscosity oil to give you the best air permeability. ADVANCED TECHNOLOGYBMC technical staff has developed a particular production system based on soft rubber moulding which produces the familiar BMC red filters. They are made in one single piece with no welded joints in the corners, thus avoiding breaking risks. This system, called "Full Moulding" comes from R&D in F1 and it is significant of BMC air filters' technical and quality specifics. BMC REPLACEMENT FILTER - FLAT FILTERModel : BA 4.0 XR6TURBO Hp : 320 Year : 02> Shape : Flat Code : 327/04 BMC has developed a particular production system based on soft rubber moulding which produces the familiar BMC red filters. They are made in one single piece with no welded joints in the corners, thus avoiding breaking risks. SUN-EX PERFORMANCE : Ask for Shawn.Address: 32, Station StreetTown: SUNBURY VICTORIAZIP Code: 3429Nation: AUSTRALIATelefone: +61 3 97444000Fax: +61 3 97407028eMail: staff@adminicle.com.au Link to comment https://www.fordxr6turbo.com/forum/topic/733-aftermarket-air-filters/page/6/#findComment-36434 Share on other sites More sharing options...
Guest atessa Guests Posted 16/07/03 01:57 AM Share Posted 16/07/03 01:57 AM Second pic BMC filter Link to comment https://www.fordxr6turbo.com/forum/topic/733-aftermarket-air-filters/page/6/#findComment-36435 Share on other sites More sharing options...
DavoXT DavoXT Member 129 Member For: 22y 4m 1d Location: 1500km north of Perth Posted 16/07/03 02:13 AM Share Posted 16/07/03 02:13 AM I have fitted a BMC panel filter in my stock airbox and love it.Made the stock XT V8 intake sound as good as my mates XR8 intake.Davo Link to comment https://www.fordxr6turbo.com/forum/topic/733-aftermarket-air-filters/page/6/#findComment-36441 Share on other sites More sharing options...
1axr TEAM BLUEPRINT Member 913 Member For: 22y 3m 13d Location: Perth W.A. Posted 16/07/03 02:27 AM Share Posted 16/07/03 02:27 AM davo xt looks good.where in wa did you pickit up from Link to comment https://www.fordxr6turbo.com/forum/topic/733-aftermarket-air-filters/page/6/#findComment-36446 Share on other sites More sharing options...
