February 10, 201115 yr #1 So randomly jump in the car a few days ago and its only boosting to 10psi instead of the normal 12. Im like hmm that's weird so did a few of the normal things check vac lines check cooler no leaks. Still comes on boost hard no un normal sounds or anything just hits 10psi and stops !! Now the only 2 things I can possibly think that may of happened are.a)Wastegate stuck slightly open ? (how do I check this?)b) Cat may of collapsed? it was a rapid cat and its like only 3 months old. How can I check if this is the case? its welded into the exhaust.I pulled the intake off the turbo no bent blades no marks on the housing and no excess play.anyone else have any ideas ? I want my power back !!
February 10, 201115 yr #2 does it feel like it's dropped power or are you just going by what the gauge reads?
February 10, 201115 yr #3 Cat can be tested by hitting it with a rubber mallet and wait for a tinging sound if it's collapsed..
February 10, 201115 yr #4 Author Im pretty sure its dropped power mick :( but that could all be in my head. im gna go to autobarn later today and re run the vac line from the gauge to the engine bay to make sure it has no kinks
February 11, 201115 yr #5 Author Mick had a quick look at the car today when I was there getting something else fixed up Great service cant wait to go back for more power :Danyway back to the issue.I re ran the line still not fixed.Mick said the actuator didnt look stuck open from what he could tell and nothing really looked wrong so im still stumped lol.If I cant sort the issue out soon I think its just an excuse to go more power sooner
February 11, 201115 yr #6 Most aftermarket cats are a POS, I have seen a GT35 SR20 silvia with a brand new 2 hour old exhaust pick up over 100rwhp at 20psi by punching out the "new" cat. We have seen 20-60hp gains on everything from wrx's to evo's to xr6's with similar mods, all in the name of testing of coarse, the cars were then fitted with a new cat of coarse. If the cat is new that would be one of the first places I'd be looking. Or a sticky boost control solenoid or something, it could be a million things.6BOOST Edited February 11, 201115 yr by 6BOOST
February 11, 201115 yr #7 Author cat is about 3 months old.was put in the same time the tune was done and ive had no issues since then.maybe its time to high flow it... lol
February 13, 201115 yr #8 Author okay I went to check the manifold bolts and the top ones were so lose so I nipped em up and it boosted fine but then the same issue came back so I think the bottom ones must be loose aswell and its decided to leak from there now. So ill let the car cool down and then nip em up and see how we go. I did get some response back I hope its this lol
