Relentless xr6t Member 20 Member For: 15y 9m 7d Gender: Male Location: liverpool Posted 20/01/11 08:46 AM Posted 20/01/11 08:46 AM hey I have completed my turbo conversion and need to take my car to ford for the parameter reset tomorow just wondering since ive put this set of mods on can I drive it around safely on a ford 6 pound tune mods are: growler cold air induction,walbro fuel pump,turbo flapper valve ported, new actuator 12psi 4 inch dump pipe into 5 inch cat to twin 2 1/2 inch 2 mufflers all exforce quiet system. can you control the 12 psi actuator to open the wastegate at 6 psi to I get a custom tune.any information would definetly help please!
ratter Member 6,793 Member For: 20y 3m 24d Gender: Male Location: @ my laptop Posted 20/01/11 10:04 AM Posted 20/01/11 10:04 AM the minimum boost you will able to run once the turbo starts to make boost is 12 psi, this will cause the stock tune to go into limp mode
