zrevival Member 6 Member For: 14y 7m 6d Posted 30/12/10 04:04 AM Share Posted 30/12/10 04:04 AM Have recently purchased an after market turbo as a replacement for the existing BA setup following an oil starvation issue to be the main turbo bearing.Have it all bolted in nicely and I'm putting the final touches on when I've discovered two small diameter vacuum lines that went to the orginal turbo setup that I can't seem to find a place to put them on the new setupDoes anyone have a picture/explanation of the old setup I could look at that will tell me where these should go? Link to comment https://www.fordxr6turbo.com/forum/topic/72428-original-ba-turbo-vacuum-lines-query/ Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 7m 25d Gender: Male Location: left right out Posted 30/12/10 05:26 AM Share Posted 30/12/10 05:26 AM Any photos? there is a vac line from the boost sensor beside and slightly below the battery, to a vac fitting on the front on the factory turbo housing. Link to comment https://www.fordxr6turbo.com/forum/topic/72428-original-ba-turbo-vacuum-lines-query/#findComment-1067704 Share on other sites More sharing options...
zrevival Member 6 Member For: 14y 7m 6d Posted 30/12/10 07:32 PM Author Share Posted 30/12/10 07:32 PM Yes - that's it. Execpt there are two vacuum lines coming from the boost sensor - one from the top and one from the bottom.Which line goes where?? Link to comment https://www.fordxr6turbo.com/forum/topic/72428-original-ba-turbo-vacuum-lines-query/#findComment-1067864 Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 6m 16d Gender: Male Location: North West Hot Hell,VIC Posted 31/12/10 09:33 PM Share Posted 31/12/10 09:33 PM Hose from front cover goes to top of boost solenoid and the bottom hose of the solenoid goes to the turbo wastegate actuator. Link to comment https://www.fordxr6turbo.com/forum/topic/72428-original-ba-turbo-vacuum-lines-query/#findComment-1068085 Share on other sites More sharing options...
zrevival Member 6 Member For: 14y 7m 6d Posted 01/01/11 12:33 AM Author Share Posted 01/01/11 12:33 AM Brilliant - that really helps.One last question - as this is an after market turbo, it came with the actuator linked via a vacuum pipe to the main housing.Now that I have this bolted into the XR6, should I run the solinoid vacuum hose to main housing (as per above quote) and the other one directly to the actuator?In other words - loose the direct housing to actuator vacuum link and run vacuum pipes as per the quote above?, alternatively should I just tap into the current direct actuator vacuum link? Link to comment https://www.fordxr6turbo.com/forum/topic/72428-original-ba-turbo-vacuum-lines-query/#findComment-1068101 Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 6m 16d Gender: Male Location: North West Hot Hell,VIC Posted 01/01/11 03:36 AM Share Posted 01/01/11 03:36 AM If it is a factory style turbo hook up the lines as per my other post, just remove the line that came on it. Link to comment https://www.fordxr6turbo.com/forum/topic/72428-original-ba-turbo-vacuum-lines-query/#findComment-1068140 Share on other sites More sharing options...
zrevival Member 6 Member For: 14y 7m 6d Posted 01/01/11 08:17 PM Author Share Posted 01/01/11 08:17 PM Ok - will try that and let you know how I get on Thanks again for your help Link to comment https://www.fordxr6turbo.com/forum/topic/72428-original-ba-turbo-vacuum-lines-query/#findComment-1068295 Share on other sites More sharing options...
F6turbo Member 172 Member For: 19y 1m Gender: Male Location: Sydney Posted 02/01/11 01:19 PM Share Posted 02/01/11 01:19 PM Has your BA been tuned at all? Do you know what PSI spring is in the new actuator? If it is higher then what you have been running previously you will run into problems. Link to comment https://www.fordxr6turbo.com/forum/topic/72428-original-ba-turbo-vacuum-lines-query/#findComment-1068528 Share on other sites More sharing options...
zrevival Member 6 Member For: 14y 7m 6d Posted 02/01/11 07:15 PM Author Share Posted 02/01/11 07:15 PM No - its the orginal factory actuator so shouldn't be any problems with that Link to comment https://www.fordxr6turbo.com/forum/topic/72428-original-ba-turbo-vacuum-lines-query/#findComment-1068541 Share on other sites More sharing options...
zrevival Member 6 Member For: 14y 7m 6d Posted 07/01/11 07:03 PM Author Share Posted 07/01/11 07:03 PM No - its the orginal factory actuator so shouldn't be any problems with thatNew turbo fitted - as per the instructions supplied with regards the boost vacuum lines.All goodThanks for the help provided Link to comment https://www.fordxr6turbo.com/forum/topic/72428-original-ba-turbo-vacuum-lines-query/#findComment-1070083 Share on other sites More sharing options...
