eastern influence Member 4 Member For: 15y 11m 19d Posted 27/11/10 06:12 AM Posted 27/11/10 06:12 AM Hi,Can anyone out there tell me the best way to rejuvenate my EF Falcon's headlights. They are the standard factory plastic ones, but are starting to fade and need to be cleaned (which is very common with them).. I belive there are headlight rejuvenation kits out there, but hav been unable to find any around my area. Is there anything anyone could recommend. It would be a great help.Cheers.
our06t Mmmmm......BOOST Member 3,135 Member For: 19y 5m 12d Gender: Male Location: central coast Posted 27/11/10 06:29 AM Posted 27/11/10 06:29 AM (edited) a good panel beaters should be able to do it for you ,using different grades of paper and a good sealer.have a look at this http://www.popularmechanics.com/cars/how-to/maintenance/4252611,probably have to order a kit over the interweb. Edited 27/11/10 06:30 AM by our06t
Rancidpunx Brisbanes Resident Detailer Legacy Donating Member 950 Member For: 17y 8m 20d Gender: Male Location: In my Cabin Outside Brisbane. Posted 27/11/10 09:59 AM Posted 27/11/10 09:59 AM Forget the kits they are a waste of money. You will need 800, 1500, 2000 wet and dry a medium cut polish and a soft finishing polish. I recommend Menzerna 203S as your medium and 85RD as your soft.Polish them as you would the paintwork on your car. Just dont allow heat to build up on the plastic though. I would also recommend a test subject first as well. Mess up something similar that your not going to miss and work out your technique first. Once done seal them as you would you paint.Good LuckHeres a couple of links you might find useful.Link Other Link
Smoke them tyres Member 557 Member For: 18y 9m 18d Gender: Male Location: Brisbane Posted 27/11/10 10:03 AM Posted 27/11/10 10:03 AM Is it that they need to be cleaned or has the clear lens gone milky/opaque?Are you using bulbs that are "UV Cut"?Polycarbonate headlights that have non UV cut run in them will destroy the clear lens in not too long at all.
eastern influence Member 4 Member For: 15y 11m 19d Posted 30/11/10 08:56 AM Author Posted 30/11/10 08:56 AM Thanks for the tips.I will have to give it a go when I get a spare afternoon..Apreciate it!
John_K Legacy Donating Member 438 Member For: 17y 10m 5d Gender: Male Location: Sydney Posted 30/11/10 10:05 AM Posted 30/11/10 10:05 AM Just give it a hit with some good old tooth paste - not gel, paste!It'll make your headlights clear and sparkle and smell fresh and minty!
Boosted_BF Legacy Donating Member 51 Member For: 16y 4m 10d Gender: Male Location: Melbourne Posted 30/11/10 11:26 AM Posted 30/11/10 11:26 AM those head light kits do work fine if done properly - but as said, replace your headlight globes with new phillips ones- phillips were the only "mainstream" manufacturer to have there headlight globes UV stabilized up until 6 months ago when narva started doing it finally (still inferior)
f-wolf Member 897 Member For: 19y 5m 15d Gender: Male Location: ACT Posted 01/12/10 03:43 AM Posted 01/12/10 03:43 AM From AutoBarn
