shaneo_1 Member 108 Member For: 19y 7m Posted 25/06/10 02:08 AM Posted 25/06/10 02:08 AM after just getting my tailshaft centre bearing replaced, I installed the tailshaft and went for test drive.all was well no noise liek it had, very smooth so seemed that the problem was fixed, turned around 2km up the road headed home then all of a sudden car shuddering, loss of power, engine sound was not good, there is a bit of a ticking sound coming from the engine, the car has a a huge shake when stationary, give a little revs and that shake goes away. Is this a bent rod or somthing else? sorta sounds like that ecu was taking all the timing out and just no power at all. neep help ??????
Smoke them tyres Member 557 Member For: 18y 9m 13d Gender: Male Location: Brisbane Posted 25/06/10 04:53 AM Posted 25/06/10 04:53 AM Does it sound like one cylinder or more than that?
hawlass Legacy Donating Member 1,161 Member For: 18y 10m 26d Gender: Male Location: left right out Posted 25/06/10 07:22 AM Posted 25/06/10 07:22 AM Could be traction control, when the steering column starts to give up(electronically) it can cause the t/c to kick in unexpectedly, do a search here on site-lotsa info, just gotta dig!
shaneo_1 Member 108 Member For: 19y 7m Posted 25/06/10 07:33 AM Author Posted 25/06/10 07:33 AM sounds pretty bad, could be more then 1 cyl, I knoiw there isnt any power in it. over the weekend I will be looking at it to see if there is a vacum line off anywere, and hopfully also a compression test. see what happens I guess.
icer Banned 2,335 Member For: 17y 2m 17d Gender: Male Location: Aspendale, Vic. Posted 25/06/10 08:53 AM Posted 25/06/10 08:53 AM did you give it a boot with less then half a tank of fuel and not running a surge tank? If so, engine rebuild time!
ebxmple Member 1,322 Member For: 18y 8m 4d Posted 25/06/10 10:11 AM Posted 25/06/10 10:11 AM Any warning lights up on the dash? They can do this if the tps or app sh*ts itself. Can you accelerate at all or is the pedal doing nothing.
Adrian6T T.P.I.S. Legacy Donating Member 2,578 Member For: 21y 10m 2d Gender: Male Location: SoR, WA Posted 25/06/10 10:30 AM Posted 25/06/10 10:30 AM (edited) did you give it a boot with less then half a tank of fuel and not running a surge tank? If so, engine rebuild time!He has a ute so no need for surge tank under 500rwhp. Dont give your opinion if you dont know. Edited 25/06/10 10:37 AM by Adrian6T
Smoke them tyres Member 557 Member For: 18y 9m 13d Gender: Male Location: Brisbane Posted 25/06/10 01:16 PM Posted 25/06/10 01:16 PM (edited) If compression ok, I would look at the ignition system.....1 or 2 dead cylinders can make it feel very anaemic.Fuel quality ok? If it has water in it, it will do this also. A litre or two of metho in a full tank should cure it. Did you put fuel in it just before it started playing up?No way of hearing the ticking you refer to, so can't suggest how important or not that may be.Could be traction control, when the steering column starts to give up(electronically) it can cause the t/c to kick in unexpectedly, do a search here on site-lotsa info, just gotta dig! Edited 25/06/10 01:19 PM by Smoke them tyres
ebxmple Member 1,322 Member For: 18y 8m 4d Posted 25/06/10 11:24 PM Posted 25/06/10 11:24 PM Just read it again,when you say you lift the revs and the shake goes away does the engine seem fine with no noises?
shaneo_1 Member 108 Member For: 19y 7m Posted 25/06/10 11:36 PM Author Posted 25/06/10 11:36 PM goin to pick ute up on trailer now, when I get it home I will answer all of the questions what its doin.
