AJJ Member 32 Member For: 16y 6m 19d Posted 22/06/10 09:15 AM Share Posted 22/06/10 09:15 AM Hope someone can tell me whats going onHave a BF XR6T manual ute, factory standard.For the past month or so I have been clearly able to hear the turbo spooling, which has been getting louder. could not before was factory quite. Have check all the hoses and there all on tight, also had a service at ford and they said they check all the hoses and there o.k.Was told they checked against other's in the yard and sounds within limits, which I find hard to believe.Now starting this week , I can clearly hear the blow off valve like an aftermarket one on gear changes or when backing off. sounds for all the world likes its had a tune, but I know it has'nt.Is there a reason a standard car would start making more boost?While I like the sounds its now making, id like to know why its now making them when before it was quite as.Does seem to be going better now, which I had put down to the cold weather.Has anyone else had a standard Xrt, suddenly become vocal. 1 Link to comment Share on other sites More sharing options...
Gypo Member 15 Member For: 14y 3d Posted 22/06/10 09:34 AM Share Posted 22/06/10 09:34 AM Hey AJJ,At the top of your engine, nearest the windscreen, on the back of the black part, labelled "Turbo Intercooled", there's a little tube that acts as a natural sort of blow off. If u take it off the nipple, you start to get the blow off sound, which is the turbine cutting up the excess air which isnt being recycled by that piping. Ive been told by several mechanics that there is no damage to the turbine, and if u want to get rid of the sound, the hose needs to be securely on the nipple.I found out about this when I got my car back from service. Sometimes they forget to reattach the little vacuum hose.Personally I quite like the sound, gives it a little bit of oomph when your driving. Ive been driving for a couple of weeks with the hose off, and whenever people hear it, they smile and comment on it.Hope this helps!P.s. My first post Link to comment Share on other sites More sharing options...
bradles024 Donating Members 1,145 Member For: 14y 5m 14d Gender: Male Posted 22/06/10 10:27 AM Share Posted 22/06/10 10:27 AM (edited) Gypo you've been more helpful in one post than most forum members in over 100 Anyway welcome mate, and AJJ don't be complaining that your car sounds good now :biggun: Edited 22/06/10 10:29 AM by bradles024 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m 4d Gender: Male Location: Probably above atmospheric pressure Posted 22/06/10 04:51 PM Share Posted 22/06/10 04:51 PM (edited) Mine started the tututu sound after I changed a fuel filter of all things. The whistle was always there.I put it down to this on my ZF auto though:Spikes to 9PSI at gear change. If I change to 3rd under boost and let off throttle it is pretty noticeable.Could be the blow off valve not venting fast enough, possibly seizing up. I've never had mine checked. Logged this data the other day with my XCAL3. Edited 22/06/10 04:52 PM by -SteveR- Link to comment Share on other sites More sharing options...
AJJ Member 32 Member For: 16y 6m 19d Posted 22/06/10 11:05 PM Author Share Posted 22/06/10 11:05 PM Thanks fella'sYer definately not complaining about the noise its now making, just wasn't sure if it was now making more boost then it should and not being tuned may be causing damaged.The car is definately going harder, but this may be the good noises making it seem like it is.don't get me wrong I do like it. just don't want to be hurting it .Will look at the nipple when I get home Link to comment Share on other sites More sharing options...
dustyn Member 6 Member For: 14y 10m 13d Posted 23/06/10 07:29 AM Share Posted 23/06/10 07:29 AM do you have a boost gauge hooked up to it?if so id be checking how much boost its making,if its making more than it should as standard without a tune you might be doing some damage.... Link to comment Share on other sites More sharing options...
o2sucka Member 242 Member For: 14y 8m 27d Gender: Male Location: Sydney - Campbelltown Posted 24/06/10 07:15 AM Share Posted 24/06/10 07:15 AM (edited) Hey AJJ,At the top of your engine, nearest the windscreen, on the back of the black part, labelled "Turbo Intercooled", there's a little tube that acts as a natural sort of blow off. If u take it off the nipple, you start to get the blow off sound, which is the turbine cutting up the excess air which isnt being recycled by that piping. Ive been told by several mechanics that there is no damage to the turbine, and if u want to get rid of the sound, the hose needs to be securely on the nipple.I found out about this when I got my car back from service. Sometimes they forget to reattach the little vacuum hose.Personally I quite like the sound, gives it a little bit of oomph when your driving. Ive been driving for a couple of weeks with the hose off, and whenever people hear it, they smile and comment on it.-----------------------------------------------------------------------------------------------------Is this the one that goes into the Rocker Cover ? The little breather looking device with a tube that runs down to the intake manifold ?Pete Edited 24/06/10 07:17 AM by o2sucka Link to comment Share on other sites More sharing options...
KeithTheBricklayer Donating Members 450 Member For: 14y 5m 6d Gender: Male Location: perth Posted 24/06/10 08:54 AM Share Posted 24/06/10 08:54 AM your turbo may be on its way out too??an steve your turbos Farked now too isnt it? ahhhaa Link to comment Share on other sites More sharing options...
Brandonn Donating Members 2,304 Member For: 15y 7m 13d Gender: Male Location: port hedland Posted 24/06/10 09:04 AM Share Posted 24/06/10 09:04 AM aahh. look who it is MR ninja himslef ^^^ Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m 4d Gender: Male Location: Probably above atmospheric pressure Posted 24/06/10 01:38 PM Share Posted 24/06/10 01:38 PM Sure is - getting replaced by Ford!!I'll ask them what they reckon happened. Link to comment Share on other sites More sharing options...
