  • Banned
  • Member For: 16y 1d
I see alot of people with aftermarket cooler thermostat. Apart from the obvious, is there any benefits from it over the standard ones? A tuning benefit etc?
Also where do you get them from and how much do they go for roughly. Just concidering if I actually need one and why.
https://www.fordxr6turbo.com/forum/topic/68500-which-thermostat-and-why/
  • Member For: 18y 2m 23d
Tridon Thermostat # TT1-190 = 82C.
Have been using one for many years :)
Super Cheap Auto, about 13.00 dollars
O-Ring Gasket Seal # TTG 11
PS, You can also get a HIGH FLOW one as well for a few more $$"s
Edited by f-wolf
Quote
" Factory O.E.M. thermostats as found in Ford falcon 5.4L V8, 4.0L T and Typhoon start to open at 93deg C and do not fully open until 105deg C.
By replacing the stock thermostat with a correctly compensated thermostat, optimum peak horsepower and torque can be achieved and maintained by optimizing factory PCM spark and fuel maps before the engine is heat soaked."
