Window Swith Lights No Longer Illuminated
Featured Replies
#1
Hi Guys,
I have a BF Mk 2 Xr6 turbo sedan and I could of sworn that I had white illuminated window switches and all of a sudden they are no longer illuminated.
Has anyone had this issue before? I thought that all Mark 2 Bf's had illuminated window switches??
Is there anyway to make them come back as I doubt they can all just die in one go..
Thanks
#2
Pull a switch out and see if its got a white/cream colour bottom section, if it is black its not illuminated. If they are they illuminated style check the 15A Tail Lamp fuse.
Matt
#3
my bf mk2 ute doesnt have them
#4
No utes come out of the factory with them unless you do a small mod to them :)
Matt
#5
  • Author
Hey thanks for that Matt, Ill have a quick look when I get a free chance and see. Im pretty sure though that they do have LED's cause I remember seeing them.
  • 3 weeks later...
#6
My illuminated switches on the drivers side stopped working.
These were modded via Matt I think.
What I found was the added pin comming through the switch body was not quite long enough or had moved back and wasn't making contact. This pin is the added when the switches are modded. It looks different to the others with the switch block out looking at the pins.
I straightened the pin and unfolded it a little then refitted the wiring connector.
All fixed.
Edited by ColinT
Recently Browsing 0
