February 24, 201016 yr #1 Hi Guys,New to this site, and new to turbo cars - please go easy!!!!I've been running around on a custom tune on a BA MkII Xr6T for a while, but need to get it services (75000ks) next week. So I attemped to flash it back to stndard/factory last night.The program seemed to upload without error messages, but when I started the car it coughed and spluttered, didn't rev and seemed to be overfuelling and generally wouldn't run.Flashed it back to the custom tune and all seemed normal again.Edit: More infoCustom tune is ~320rwk on 98octaneCar Mods - injectors, nizpro 1+ kit with coolerThe o2 sensor is disconected with the custom tune, woudld this cause this problem if left disconected for the factory tune??Any help is appreciated...CheersDave. Edited February 24, 201016 yr by daves3
February 24, 201016 yr #2 That could be your problem as on the std tune the ecu will use the o2 sensor to measure the richness or leanness of the air/fuel mixture. Maybe try plugging it in and reflashing.
February 24, 201016 yr #3 Author Yep thanks, that was the plan for tonight.Any other suggestions?I realise the info is a bit limited...
