  • Member For: 21y 5m 22d
Posted
hey guys
I got a problem, I installed gauges today boost and vaults and in doing so I took out my icc unit
now I have connected everyhtig back up but it says security code error and my car will not even start now, not even turn over
any ideas guys
  • Member For: 17y 5m 11d
Posted
I think you may two different problems. The security code error is related to the ICC just type in the code and you car not starting or turning over may be a fuse blow check the two fuse boxes.
Posted
fuses hey wow
ok I wil check that out in the morning
any ideas which ones I should check
I had the gauges get power from the 12v inlet
  • ORSM Ford Cruisers!
  • Legacy Donating Member
  • Member For: 21y 3m 27d
Posted
Check to make sure that the ICC has clicked into the plug properly. Remove the ICC and ensure that the plug is all the way out and re install making sure that it clicks into place.
Matt
Posted
It may be in smartshield mode, is the smartshield light flashing?
  • Sucker
  • Moderating Team
  • Member For: 22y 5m 1d
Posted
Nah, would more than likely be the same problem. There is no code to key in, the ICC and BCM must be able to communicate or nothing will happen.
Sounds like a plug is not seated properly as per ORSMBA :bangcomputer:
  • 10 years later...
  • New Member
  • Member For: 6y 5m 19d
Posted
Hey I have a 2005 ford felcon bf Fairmont Ghia 6c and it want start nothing and the security code error keeps coming up it want click ova nothing any ideas why ?
