25/01/10 04:29 AM25/01/10 04:29 AM #1 Does it make any difference to shorten the pipe from the front turbo housing to the standard crossover and add a pod? I have added a circle around the pipe I am talking about. Edited 25/01/10 04:30 AM25/01/10 04:30 AM by mitchbek
25/01/10 04:45 AM25/01/10 04:45 AM #2 I bought another pipe to cut up so I could keep the original intact and under my bed, I recommend doing the same.I originally cut the pipe how you describe and added a pod, made sh!t loads of induction noise and sounded mad, took the BOV off and it dosed very loud. However, once summer hit the car is a slug on 35 degree days. During winter it was fine.I have just moved the pod to the position of the airbox so that air is a bit cooler. This is where the second pipe comes in handy. I used the original and the cut up pipe to do this. The cut up section which I didn't use as a dose pipe nicely locates the pod in the airbox position which looks stock.Performance wise I can't tell which works better, the intuitive thing would be the airbox location is better but once you get heat soaked it doesn't matter anyway Edited 25/01/10 04:47 AM25/01/10 04:47 AM by MICKAJ
25/01/10 04:45 AM25/01/10 04:45 AM #3 Yes, car will feel like driving a GETZ with all the hot air it will be sucking in
25/01/10 05:03 AM25/01/10 05:03 AM #4 haha speaking of spare pipe, thanks Henz. The dose is long and strong sraight off the turbo!Didn't notice much drop off in winter though, summer sucks balls! Edited 25/01/10 05:03 AM25/01/10 05:03 AM by MICKAJ
25/01/10 05:34 AM25/01/10 05:34 AM #5 Best way to do it so you can keep your original pipeAll these parts u can get from autobarn.3" Silicon Joiner90 Degree Bend, 3" ObviouslyCheap, mushroom style pod (Bigger ones may fit, not 100%)AssembleAnd remove the original pipe and squeeze on using your original clamps. Too easyFinished product
