trevs Member 781 Member For: 19y 5m 8d Gender: Male Location: balmain Posted 19/01/10 01:12 PM Posted 19/01/10 01:12 PM (edited) im pretty sure for a standard car (xr6t) ford say about 1.1mm but tuned everyone as far as I know runs about .8mm if I where you id try .8mm closing it up a bit isnt going to hurt your engine BTW VCT Infinite over 60 Deg - standard on BA Mk 1 XR6T, could this be the issue?sorry mate but I really dont know enough about vct to say yes or no im sure somebody who knows will come along soon enough cheers trev Edited 20/01/10 12:21 AM by tab Quote removed
Kellar Member 51 Member For: 16y 8m 12d Posted 19/01/10 01:16 PM Author Posted 19/01/10 01:16 PM (edited) Thanks for the info, appreciate the help Edited 20/01/10 12:21 AM by tab Quote removed
straughsberry Legacy Donating Member 1,846 Member For: 19y 1m 11d Gender: Male Location: Broady, Melbourne Posted 19/01/10 01:21 PM Posted 19/01/10 01:21 PM Make sure the cam angle sensors are plugged in correctly and the wires are in good order. They are located at the very rear of the head right near the firewall. Especially the one on the exhaust side as it deteriorates because of heat. Unplug one at a time and go for a drive. It there's no difference, there's ya problem!
Kellar Member 51 Member For: 16y 8m 12d Posted 19/01/10 10:51 PM Author Posted 19/01/10 10:51 PM (edited) Thanks for the tip, will give it a try Edited 20/01/10 12:22 AM by tab Quote removed
atto666 Member 35 Member For: 19y 6m 3d Gender: Male Location: liverpool, sydney Posted 21/01/10 01:18 AM Posted 21/01/10 01:18 AM from experience this to me sounds like a stuffed wastegate actuator.after witnessing higher than tolerated boost levels the pcm will switch 3 cylinders offto bring the boost level down, which is the 'breaking down' you feel.it continues for 20-30 seconds or until a free rev is undertook.
