  • Legacy Donating Member
  • Member For: 17y 9m 27d
Posted
please comment on my new oil drain pipe, my old one cracked so I had a custom one made up.
  • Member For: 18y 4m 26d
Posted
Looks better than the stock item.
Posted
nice , what kinda price?
its not cheap $250 the fittings and labour was the killer
  • Member For: 18y 8m 15d
Posted
looks nice, but id really like to see it out perform the stock item. do u have a high mount ? if so the heat will eat straight through it. it needs to be all metal, just way too hot in there.
Posted
its was designed to handle the heat, and its a direct replacement for the low mount.
  • Member For: 18y 9m 12d
Posted
How does the inside diameter of the flex section compare to the std one? Large enough to carry the volume of drain required?????
  • It's not a MKI!
  • Member For: 18y 3m 14d
Posted
Why was labour the killer?
Looks like a short section of hose and some fittings to me. :beerchug:
Or was that price including removal and refit?
Looks like an alternative option to the standard item anyway.
What is the standard item worth?
Posted
the inside diameter of the flex section compare to the std one is the same, the labour was expensive because it was difficult to get the right angle and weld but now they have made one I guess it will be easyier.
Not sure on the standard items price.
Posted
item installed today my self and my mechanic have leak tested it and no leaks and have been driving all day so far so good.
