Peter J Member 37 Member For: 15y 9m 21d Gender: Male Location: Melb. Posted 13/12/09 08:56 AM Share Posted 13/12/09 08:56 AM I'm looking at putting a X-Force 4" Dump pipe with high Cat on my BF F6.(Auto)Anyone tried these and are there any issues with fittment (not fitting correctly,knocking etc..) or engine light coming on?I will be getting a custom tune soon after fitting.It seem there are a few problems with high flow cats causing engine lights to come oneven after a custom tune ?Any help would be appreciated.Cheers Peter.0418 338 005 Link to comment https://www.fordxr6turbo.com/forum/topic/64319-x-force-4-dump-high-flow-cat/ Share on other sites More sharing options...
Ford powa Member 111 Member For: 16y 9m 8d Gender: Male Location: North West Aus Posted 16/12/09 11:53 AM Share Posted 16/12/09 11:53 AM Will be interested in what people say. My next upgrade on my BF F6 will be upgrading the stock exhaust and cat, since my car will be clearly running over 300rwkw's after tuesday next week. Link to comment https://www.fordxr6turbo.com/forum/topic/64319-x-force-4-dump-high-flow-cat/#findComment-963754 Share on other sites More sharing options...
kb351 Donating Members 80 Member For: 17y 7m 8d Gender: Male Location: Perth Posted 18/12/09 06:43 AM Share Posted 18/12/09 06:43 AM I had the engine light come on after fitting a high flow cat when I ran the stock dump pipe. As exhaust gas/flow etc did not correspond with factory parameters. It was sorted by my tuner and I expect yours would so the same.I am currently running a Xforce 4" dump into Xforce high flow cat and intermediary piece back into stock centre/rear muffler and the dump did slightly touch some of the heat shielding around the steering which was a real annoyance with intermitant vibration/noise. I have since had a small section of the shielding removed which doesnt seem to have affected anything and the noise is gone, so its all good. Link to comment https://www.fordxr6turbo.com/forum/topic/64319-x-force-4-dump-high-flow-cat/#findComment-964299 Share on other sites More sharing options...
FPV FG F6 New Member 14 Member For: 15y 4m 28d Gender: Male Location: perth Posted 29/12/09 10:13 PM Share Posted 29/12/09 10:13 PM I had the engine light come on after fitting a high flow cat when I ran the stock dump pipe. As exhaust gas/flow etc did not correspond with factory parameters. It was sorted by my tuner and I expect yours would so the same.I am currently running a Xforce 4" dump into Xforce high flow cat and intermediary piece back into stock centre/rear muffler and the dump did slightly touch some of the heat shielding around the steering which was a real annoyance with intermitant vibration/noise. I have since had a small section of the shielding removed which doesnt seem to have affected anything and the noise is gone, so its all good.Hi mate what does it sound like and any power gain with xforce set up? Link to comment https://www.fordxr6turbo.com/forum/topic/64319-x-force-4-dump-high-flow-cat/#findComment-966844 Share on other sites More sharing options...
