  • Member For: 16y 10m 8d
Posted
Hey all
03 BA XR6T 5 speed.
wondering if anyone can help...
noticably when im drinving, can be any gear, if I back off the throttle and push back on it, I get a noise from around the diff area. its a clunking noise and iv only noticed when I back off and give it again.
any ideas of what it is and if its a prob, how its fixed.
thanks
  • Legacy Donating Member
  • Member For: 20y 8d
Posted
Standard.. mine does it also
  • Member For: 17y 10m 1d
Posted
Diff bush needs replacing
  • You are a dead set goose
  • Member For: 20y 10m 6d
Posted
I've got nolathane bushes and it still does it :bum:
  • Member For: 17y 5m 18d
Posted
hey wandering if anyone knows what happens when this gets bad, mine has stopped clunking but now when I back off the whole car jerks (like it would if you were rolling slow in first) but this does it in any gear even when braking would this be from the diff bush?
Posted
Could be that or the tail shaft or the tail shaft centre diff bearing or the bearing mount or a couple of other things. Best thing to do is to take it to a good suspension/brakes/driveline shop and let them figure it out. They most likely won't charge you until they give you their findings and you give them permission to fix it so finding out what it is would be free! Either that or ask Ford to check it when you get it serviced.
  • Member For: 21y 3m 23d
Posted
Just Ford quality parts, my F6 went through 3 diffs in 8000 kms, all covered by warranty, by the third one I just gave up and learned to live with it.
Russ
