normda Member 30 Member For: 17y 5m 3d Gender: Male Posted 14/11/09 08:35 AM Share Posted 14/11/09 08:35 AM im not sure what happened, but I went to the petrol station and put in half a tanks worth...hopped back in the car and the fuel said it was still on empty with 10km range!!! has a plug or a wire disconnected somehow??? it was working fine last nite. I have noticed there is a wire with a plug on it coming out of the ecu that isnt connected to anything. its a rather short wire (10cm max) and ive looked everywhere in the wires range but theres nothing for it to get plugged into :S Link to comment https://www.fordxr6turbo.com/forum/topic/63570-fuel-readout-error/ Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 3m 16d Gender: Male Location: Sydney Posted 14/11/09 09:01 PM Share Posted 14/11/09 09:01 PM It could just be a stuck float on the fuel sender.I would fill up the car and see if that makes any difference.If not, you most likely will need a new fuel sender, it is not a common problem but has happened to others. Link to comment https://www.fordxr6turbo.com/forum/topic/63570-fuel-readout-error/#findComment-953988 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m 5d Gender: Male Location: Brisbane Posted 15/11/09 07:21 AM Share Posted 15/11/09 07:21 AM ...and the spare plug under the ECU is normal, same wiring loom across all falcons but isn't used on the turbos Link to comment https://www.fordxr6turbo.com/forum/topic/63570-fuel-readout-error/#findComment-954133 Share on other sites More sharing options...
normda Member 30 Member For: 17y 5m 3d Gender: Male Posted 20/11/09 08:41 AM Author Share Posted 20/11/09 08:41 AM I put in a bit more fuel and about 10km later on the freeway it suddenly fixed itself :S very weird... Link to comment https://www.fordxr6turbo.com/forum/topic/63570-fuel-readout-error/#findComment-955802 Share on other sites More sharing options...
