  • Member For: 15y 9m 14d
  • Gender: Not Telling
Hey guys look I'm a bet eccentric
I am trying to bullet proof my car and I am looking for any ideas
or feed back to see if I m forgetting anything or am misguided on
some topics
firstly I AM SUPERCHARGING NOT Turbocharging
secondly money is not an issue (its not like I have a lot of money
it just I have no life except my car)
also I know a lot of this is overboard but hey
ok so far I have loaded the diff with a two way lsd tomei setup
I have been told this is bullet proof
I have Frankensteined the gearbox
(drilled out the valves, gmh adjustable solenoid, different planetary gears
I am not sure wich ones either au wich have meatier teeth or xr6 turbo or something else, gone from the standard 16 ml pump ro 26 ml pump so there is enough pressure left over to pump auto trans oil through the cooler)
seperate auto trans cooler
bilsteain shockies, whitline sway bars, king springs,
I think that is all performance wise so far
I also want to forge the engine, pistons, rods bolts,
I will change the valve springs,
I want the new pulleys (billet or alloy or whatever)
slotted and dimpled rotors
I also want to buys the tools and the hoses to re-run
and change ALL the lines to braided lines (ALL)
new radiator to try and setup a better system than stock
water to air intercooler due to piping issues with a supercharger
my target first up is 300rwkw
and making sure my caris bullet proof before going from there
any sugestions would be muchly appreciated
Edited by zzz-ba ute
https://www.fordxr6turbo.com/forum/topic/63142-bullet-proof-car/
  • Need more power. Now taking donations.
  • Member For: 16y 3m 16d
Love it. Great idea. Its good to see someone with the ambition to create something strong for their needs. If your target is only 300rwkw, you'll have no issues whatsoever with anything breaking.
But, what engine etc are we talking here?
  • Member For: 15y 7m 16d
hmm...the topic is miss leading.... I was excited when I saw bullet proof car... hah
IMO anything apart from stock is not bulletproof. Anything can go wrong at any time anywhere. BUT... I see atomic engines been rock solid and good for 9sec passes.
If your chasing 300 then that's a 'safe' figure according to many tuners. Even though if you boost spike or get a bad fuel run etc....it can still blow ;(
I have a 2003 ba xl ute, I bought the base model because I was changing everything anyway eg suspension, diff, etc
im building it more like a track car than a drag
car, however it gets plenty of lights work
also its a 6
  • 2 weeks later...
  • Member For: 15y 9m 22d
go to the nizpro website...theyre building a serious ute themselves... apparently using a skyline IRS. But yeah...why supercharging?? Turbocharging is much more efficient..but ..if youre after a challenge...why not. As for the no issue with cost... why dont you choose a ferrari??? :buttrock:
