September 24, 200917 yr #1 Hi Guys,Like most newbies I'm not sure if this is in the right section, but from where I'm sitting this seems like an electrical problem, so I hope you can help.To start with, the car is a 2003 BA XR6T Mk I with approx 95,oookm- pretty much completely stock except for second F6 intake and K&N filter.To try to shorten a very long story(issue), the problem I'm currently having, started with the usual stalling engine problem when pulling up to lights etc. I put up with this problem for a while until I got on the forum and did some research.From that research I came to the conclusion that it was the throttle body or TPS, but wanted to know exactly which was to blame. So instead of replacing the whole throttle body and TPS at once, I replaced just the TPS to see if it would fix the problem - it did, hasn't stalled since. However, now the only time it drops in revs like it use to just before it use to stall, is when I have the lights turned on. It happens like before, pulling up to lights etc, the revs drop below 500rpm for a split second, then pick back up, no stalling just drop in revs. It reminds me of exactly how it use to behave just before it would stall proir to replacing the TPS. Also if while I'm sitting at the lights and the revs are sitting at normal idle, if I push the power windows button, the revs drop by maybe 100rpm. Is this an alternator issue or something even simpler that I'm just not seeing?Hopefully someone might have had the same issue and can help, or its just an obvious answer that with my limited knowledge, am yet to figure out. Sorry for the dragged out "shortened version" of my problem.I would welcome any help or advice you may be able to offer me on this topic. Cheers,XR6TNewbie
September 25, 200917 yr #3 Author Battery is only about 3 months old. Due to all the stalling and restarting, the battery died. NRMA guy that came out to jump start me, checked the alternator and said it was charging fine, as did the Marshall battery guy that replaced the battery. But I'm still not convinced?
September 25, 200917 yr #4 Could also be a dodgy earth.I had a similar issue with a BA XR6.If I got all the ducks lined up it would stall.ie. The aircon compressor cut in, I turned the steering wheel and also dropped it in drive. With all of those things happening at the same time there was too much load on the engine for the brain box to pick it up and raise the revs. Hence the stall.I'd be checking the earth points and cables if I were you.
September 26, 200917 yr #5 Author Thanks for the input, I'll check out the earth points and cables and see if I come up with anything.
September 26, 200917 yr #6 nup nup nup, just clean other thethrottle body man, doesnt sound like alt at all 2 me.
September 26, 200917 yr #7 From my experience with my BA and BF, this was the first sign of a dying battery. And I've had faulty batterines aswell. Get it tested by the people u purchsed it from, but if you don't change it you'll find yourself stranded. Double check the connections are tight. BTW - What brand is the battery?
September 26, 200917 yr #8 I had a similar problem with a BA taxi at work, stalling at lights ect. I think It ended up being a fault with the actual motor on the throttle body, Ill double check on Monday and get back to you.
September 28, 200917 yr #9 Talked with my boss today, turned out to be the transmission causing it to stall, Unfortunately I don't know exactly what caused it because the trans was repaired else ware.
