July 3, 200917 yr #1 hi all went to start my car after a short drive to the shops. and Nothing! the RAA came out and it started first time, so confused I tried agin and again and eventually it stopped workin. the raa guy did some tests and came to the conclusion that the started motor was stuffed. so while I had the key to start he gave it a nudge with a metal pole and it kicked into life. the car is a BFmkII turbo with 42000 on the clock. has anyone had any starter motor problems like this and does anyone know how much a new one is.cheers
July 3, 200917 yr #2 never heard of a starter issue with these .usually on other cars ive had it's just the solinoid on the top of the starter that goes can be cheaper than replacing the whole thing but must say never really took much notice of the xr set up as it was solid have you been driving through a lot of water or something
July 3, 200917 yr #3 just make sure you havn't got a rear main seal leak and the starter is getting oil in it.I had a problem with mine and was do to lots of fried clutch and soot on it tonot slide the gear out on the shaft to engage.If yours is like this you may hear it spin but the cog wont engage the ring gear.The RAA tapping the solinoid would help it to engage.Not a hard job to remove and give it a clean.Remove it and give it a good wash in kero, rinse it (Pressure clean if have one)Blow it dry with a compressor, get some lithium grease and smear a very light coaton the shaft. Then try to pull gear in and out a few times to work the lube into it.If you cant do so just hook up your cable and wire without inserting it back into position.Hold it tight and have some one hit the key a few times.Observe if the gear is spinning out to engaging position.Now even though it does all this wont mean it is ok as when there is a issue its the load thatstops them.Also while you have it out, check that there is no burred teeth on your ring gear and starter gearas this will also stop engagement.If it does work at least you have saved yourself a starter motor.Good luck.
July 3, 200917 yr #4 I have had that exact problem in my BA MK11 where the cog does not engage at all. It always happens when I am in the middle of no where. I will give your method a try!Thanks very much for the useful informationCheers Alf.
July 4, 200917 yr #6 Author thanks for the replies and for the tips. its under warrenty but dont know how id go with my mods? it hasnt happened since but its still notgood hopefully I can get it up on a hoist and have a look at it.cheers
July 4, 200917 yr #7 Your mods shouldn't affect it for warranty on the starter unless it is directlythe cause of the problem, it may affect the engine drivelines warranty once they see the mods.
July 4, 200917 yr #8 Just remember if it is really stuffed and you play around with it they might void your warranty. But in saying that I would probably do the same.
July 5, 200917 yr #9 Author thanks for the tips guys it happened again today but now I know where to hit, its no worries I gotta get some time of work to book it into ford cheers Edited July 5, 200917 yr by mjadeb1984
July 5, 200917 yr #10 thanks for the tips guys it happened again today but now I know where to hit, its no worries I gotta get some time of work to book it into ford cheersDon't leave it to long as if it is gunking up it will only get worst to the point it wontengage no matter how hard you beat it up.Just get a can of wd40 and see if there is anyway you can give it a squirt into it.It may just help enough to get it working till you either pull it out and fix or replace it.If its manual dont get any on the clutch plate.Auto and your fine to give it a good dose of wd40.Make sure you aim for the shaft cog area.
