Mark Korsch Inactive Members 1 Member For: 16y 4m 11d Posted 25/06/09 10:52 AM Share Posted 25/06/09 10:52 AM Hi guys, I've got 2 seperate issues here but I'll start with the biggest first. I've recently had some work done to my TTG which I bought new March '08. I originally purchased a flash tuner at christmas which I was told had a 10psi tune. This was great, however wanting to do the job properly I had bigger injectors and a custom tune done, which came out to be around 280rwkw at 12psi. Since then I've had a couple issues, the biggest one was the engine light kept coming on for an O2 sensor issues. We replaced the 2 with new ford varients (no warranty apparently) which brought out another issue "too rich bank 1" was the code my ford guru told me. The light only came on around 15-20% engine load at low speeds. The tuner has since fixed this issue I think (been OK so far this week). The 2nd issue has been ever since the injectors have been fitted we've had 'surging' issues. Between 2000-3500rpm, the boost seems to come on and off fairly severely sometimes even noticable when towing up a slight incline at 100km/h. I've included a dyno sheet which should give a bit of an idea. My question is, would this be a tuning issue or should I do a boost actuator upgrade or am I completely on the wrong track?2nd issue is a similar sort of one but not to the same extent. I've got a 2005 BAII XR6T 6speed which at the same time as the territory I've had the following mods done, Injectors, Intercooler, Fuel Pump, Cat, Dump Pipe, Exhaust, Valve Springs, Boost Actuator and Clutch. Came out at around 325rwkw. The problem here is similar, boost come on and off, but not nearly to the extent, around 0.5psi according to the tuner, which he suggested would be fixed by fitting a 'flapper wheel' for around $500 and could be done without needed a retune.Just wondering if the tuner is on track and if the pricing would seem accurate? Its a bit of a distance for me to travel to the tuner and was wondering if I could source the parts and fit myself easily?Any help would be much appreciated! Dyno sheets below, Thanks! Link to comment https://www.fordxr6turbo.com/forum/topic/58929-turbo-territory-ghia-baii-xr6t/ Share on other sites More sharing options...
stevet Member 85 Member For: 17y 21d Posted 14/07/09 08:41 AM Share Posted 14/07/09 08:41 AM Hey mate did you ever get this sorted? If so what was the cause?...... Link to comment https://www.fordxr6turbo.com/forum/topic/58929-turbo-territory-ghia-baii-xr6t/#findComment-906486 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 6d Gender: Male Location: Melbourne Posted 14/07/09 09:09 AM Share Posted 14/07/09 09:09 AM How long have these cars been out?? God any half decent tuner should be able to fix these problems. Link to comment https://www.fordxr6turbo.com/forum/topic/58929-turbo-territory-ghia-baii-xr6t/#findComment-906509 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 25d Gender: Male Location: SW Sydney Posted 14/07/09 09:50 AM Share Posted 14/07/09 09:50 AM I think a second opinion on the tune would be a good idea... Link to comment https://www.fordxr6turbo.com/forum/topic/58929-turbo-territory-ghia-baii-xr6t/#findComment-906537 Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 10m 5d Posted 14/07/09 11:14 PM Share Posted 14/07/09 11:14 PM The AFR's are too rich to start with. Do you have boost graphs? Link to comment https://www.fordxr6turbo.com/forum/topic/58929-turbo-territory-ghia-baii-xr6t/#findComment-906882 Share on other sites More sharing options...
