winstor Member 611 Member For: 17y 7m 5d Posted 01/06/09 01:35 AM Posted 01/06/09 01:35 AM Has anyone got any diagrams or pictures of somewhere I can obtain power from a +12v ignition source? The gauges need it as to calibrate properly.
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 18y 3m 14d Gender: Male Location: Earth Posted 01/06/09 02:08 AM Posted 01/06/09 02:08 AM Just use the supply off the back of the cigarette lighter socket.
winstor Member 611 Member For: 17y 7m 5d Posted 01/06/09 02:46 AM Author Posted 01/06/09 02:46 AM that's where the power is coming from atm, the ciggy socket. It needs a +12v feed that stays active during engine cranking.
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 18y 3m 14d Gender: Male Location: Earth Posted 01/06/09 05:21 AM Posted 01/06/09 05:21 AM I don't think you'll get a 12 volt feed when the engine is cranking due to volt drop.You can run a fused cable from the + terminal of the battery if that helps?
Mike XR6T iTs alL DaRDy........ Legacy Donating Member 780 Member For: 19y 28d Gender: Male Location: Adelaide Posted 01/06/09 06:30 AM Posted 01/06/09 06:30 AM the ignition switch will have a 12volt ignition feed out that is on with the ignition and also while cranking just pick it up from there and fuse it! easy as, as for the colour I dunno of the top of my head mate!PHANTOM XR6 he doesnt mean it has to always be 12v as your rigfht during cranking it will drop to 9-10 volts but as long as the feed doesnt cut out during cranking the gauges can continue calibration. gauges dont need anywhere nere 12v to opperate anyway for exactly that reason
winstor Member 611 Member For: 17y 7m 5d Posted 01/06/09 08:15 AM Author Posted 01/06/09 08:15 AM Yeh the gauges are already fused with the recommended type, just would like to know exactly what I am looking for in the form of pics, diagram etc
ysoslo Member 28 Member For: 18y 10m 8d Posted 03/06/09 03:33 AM Posted 03/06/09 03:33 AM best bet is to get yourself a test light and start searching for a constant source, or go directly to battery as already mentioned
