  • Member For: 16y 8m 25d
hey guys I want to get myself some dba4000 and pads 2morro but how long until they wil be right for heavy breaking? got the cruise 2morro night and want to make sure they will be right
https://www.fordxr6turbo.com/forum/topic/57458-dba4000-run-in-time/
  • My engine bay is Bionic
  • Member For: 19y 1m 23d
Drive to the cruise meet up point with one foot on the brake and you should be right. My bed in procedure was last years snowies cruise, but getting there Kms was enough.
I.B.
  • 2 months later...
  • Member For: 15y 10m 13d
Hey Lukexr61988,
Hope the 4000 series are working seamlessly for you.
Just a note on bed-in procedure.
1. After installing new disc rotors &/or brake pads, perform 8 to 10 slow downs applying moderate pressure from approximately 50 – 60 kph without coming to a stop.
2. Make an additional 2 to 3 slow downs applying heavy pressure from approximately 60 - 70 kph without coming to a stop.
3. DO NOT DRAG BRAKES!
4. Check that the discs have an even surface appearance (they should be a consistent blue tinge)
4. Allow at least 15 minutes for brake system to cool down.
After step 4 your new disc rotors &/or pads are ready for normal use. Be aware that the full bedding in process can take up to 300 – 500 kms depending on driving style. During this period try and avoid any high speed hard braking to a dead stop.
This process essentially 'pairs' the pad to the disc and allows a good heat soak for both the pads and discs.
If you need any more info, just ask.
All the best.
DBA Steve
dbasteve(at)dba.com.au
  • Member For: 17y 4m 21d
I got mine installed yesterday (4000's) with some Race Brakes pad - and they feel quite soft,they dont start to bite as soon as the pedal is touched like the standard ones did, for example when foot is lightly on brake there is no light braking at all until maybe 3 or 4 centremetres.. but work great otherwise
Is this normal?
Sorry to hijack the thread mate :beerchug:
Still pretty ordinary... done 320km now. Still 4 or 5 cm till anything really works.
Yeah they work ok, but compared to the stock ones that were on there, they arnt anything special.
Starting to think something is up.
They should be VAST improvement.
  • Cruise Whore
  • Moderating Team
  • Member For: 19y 9m 7d
I've had new dba 4000 slotted rotors and Race Brakes RB24 pads on the front of my BA XR6T now for about 1 month now and done about 800kms with them. My brakes start to slow the car down after about 1cm travel on the brake pedal. 4-5cm pedal travel sounds unusual to me before your car starts to slow down. In my opinion, I'd have it checked out independently by a different brake specialist or a brake specialist if you put them on yourself.
I read in another thread about needing to do something with a brake compressor to squeeze the piston back in here.
Edited by EvilDaifu
