Xr6 And Xr6t The Same?
Featured Replies
#1
are the XR6 and XR6T exactly de same xcept de turbo? some1 told me dis :drivingalong:
#2
Turbo has the following that the N/A doesn't have.
2 piece drive shaft
LSD diff
power rear windows - these can be optioned in the N/A
approx 55kw extra
Different exhust, if you look at an N/A you will see that only half the exhust tip is used.
The Turbo under the bonnet with intercooler and plumbing.
Driver with permanent smile.
Hope this helps. :drivingalong:
#3
I parked my xr6t "ute" next to a n/a xr6 sedan and my ute was about 30 - 40mm lower in the front end, so I wonder if the T is lower than the n/a??
#4
2 piece drive shaft
LSD diff
approx 55kw extra
Hope this helps. :huh:
You forgot to mention the five little red badges on the back of the car.
T, U, R, B, & O. :D
#5
How right you are.......
that magic little red word...
Ahhh yes.........
Sex?...............yeah I think I remember what that was.........before the T came along.
Ooops, Lucky SHMBO does not get to read the forum........Would be most diss-pleased!!!!
#6
My TURBO badge is black...had it specifically changed at delivery...goes nicely with the Narooma paint job...(its also the colours of the footy team I support) - "THE MIGHTY ROYALS"
#7
Could you post a pic of this? I would love to see what it looks like.
#8
The whole falcon range except the wagon have a two piece drive shaft.
The turbo also has different pistons to reduce compression.
#9
I'll see if I can post a few pics of the beast BlueXRGTurbo
#10
You forgot the Sodium valves too!!! :thumbsup:
Recently Browsing 0
