March 10, 200917 yr #1 Hello fellow T owners,Basically whats happening, hoped in car this morning and when building up to speed my car had a real high pitched noise.When looking at boost guage no boost was building and felt slower then a N/A car by far.I check the two top turbo hose's and they appear fine.If I run on Cruise Control and such it's fine no noise and when building up speed.Any ideas?
March 10, 200917 yr #2 check all turbo pipes and all nuts and bolts are there, it will be a leak somewhere
March 10, 200917 yr #3 Better not be another turbo comp wheel that will be the third in 2 weeks, but it sounds like a house has blown off.
March 10, 200917 yr #4 'sCheck all intake pipes by simply following from the airbox to the turbo, turbo to cooler, cooler to TB. If you find a loose clamp or busted hose, simply tighten or replace it If the problem persists, you may have loose turbo bolts/studs. You need to remove the heat shield & tighten/replace the 4 bolts holding the turbo to the exhaust manifold...
March 10, 200917 yr #5 Author 'sCheck all intake pipes by simply following from the airbox to the turbo, turbo to cooler, cooler to TB. If you find a loose clamp or busted hose, simply tighten or replace it If the problem persists, you may have loose turbo bolts/studs. You need to remove the heat shield & tighten/replace the 4 bolts holding the turbo to the exhaust manifold...I'll check all pipes, going to book in for service anyways due for 75,000km and is sitll under warranty!
March 10, 200917 yr #6 Better not be another turbo comp wheel that will be the third in 2 weeks, but it sounds like a house has blown off.Nothing worse than we your giving it a bootful and your HOUSE blows off......goddamn i hate..... sorry purvy, couldn't help myself
