  • Member For: 17y 2m 21d
A mate of mine is now building engines too, works for Top Torque Engines here in Melb, so things like valve springs will be nice & cheap. He's gonna look into what other head work can be done cheap while its off!
And when it's time for mt forged motor, I might save a bit too!
What do I need to do to the exhaust to get my 300kw? Apart from the cat obviously. Is the typhoon intake good enough, or do I need something better? And I found a Monza IC on ebay today for $450, will that do the trick?
Sorry, bout all t he questions!
  • Replies 33
  • Member For: 20y 8m 20d
zomg.....
youve gone from a plazmaman 1000hp kit to a wogcooler....???
do you know WHAT you want?? :blink:
  • www.australianflag.org.au
  • Member For: 19y 10m 12d
500 rwkw =30 k to 50 k in mods.
300rwkw =15 k in mods.
I am talking complete packages here brakes suspension etc.
Scotty
zomg.....
do you know WHAT you want?? :huh:
I would love the plazmaman kit, but as I've decided to aim for a bit less power, Im not sure if it's worth spending so much money & the plazmaman cooler doesn't look like it can be used with the stock cross over piping & airbox.
Thanks Scotty, I hadn't even started looking at suspension & brake packages yet. But I do have the bigger rotors from a BF on it & it's been lowered.
It has major brake shudder, so its getting new pads & rotors this week. The shocks are also a bit tired, so I'm thinking a pedders sportsryder kit might be next.
Edited by EXGMH304
you can use all the BIG coolers with the stock crossover mate... you just need to purchase the piping kit to suit.
that way in the "future" you can upgrade to 11ty billion killawatts.
Perfect then, I'll keep an eye out for a 2nd hand plazmaman cooler, but I'll probably end up with a new one.
I like this car more & more every day! If I wanted to upgrade my v8 Late model camira from 300 to 11ty billion kilowatts I would have had to throw trhe engine in the bin and start all over again. I've been working on the theory that I would have to go all the 1st time round, or do it twice!
So what about the exhaust then? Just a cat for now, or do the lot???
  • loitering with intent
  • Member For: 21y 9m 10d
Do the cat as it is quite restrictive stock. Also consider removing the centre muffler with straight throughs or hot dogs. Won't add a heap of power but will sound heaps better. First mod for some.Cheap to
  • Mmmmm......BOOST
  • Member For: 18y 1m 1d
just cat will do ,,,But
I'm looking at a ces racing unit at the moment , what they call a starter pack ,it's a twin dump pipe , 31/2 in cat and a section of pipe that will bolt to the first join on the factory system , around $1500 -$1600
Edited by our06t
Twin dump into a 3.5 inch cat into the factory system is a rip. sorry you can do better than that.
Why would you try and squeeze the exhaust gasses from a a twin dump into a restictive 3.5 inch cat ??
Curious as to the twin dump and the benefits however :blush:
  • Mmmmm......BOOST
they have done a lot of testing and have a very good name backed by independant tests
and I will upgrade to the rest of their system down the track
the cat is a custom design by them and the starter kit alone has givin a 29rwkw gain over a factory unit on a stock car .
the full system has givin a 40+ rwkw gain on a stock car but is around 3k I think
so I'm keen to give the starter pack a go first ,
reply to my inquiries below
Ford XR6 Turbo 3.5" Turbo Twin Dump Pipe
Mild steel painted (high temp. paint) Lasts well RRP $750.00 incl. GST. Comes with fitting inclusions.
3.5" Turbo Twin Dump Pipe with optional Polished Aluminium Ceramic Coating (inside/outside) pipework * see photo shot attached RRP $899.00 incl. GST.
EXPECT POWER GAIN 29 KW @ THE WHEELS INCREASE FROM STANDARD.
CES Racing Systems have a great full system for your model vehicle. Great sound, legal DBS, PLUS 41+ KW @ THE WHEELS POWER PICK UP (increase) from standard. (untuned). Huge gains (further) with tuning after exhaust fitment.. highly recommended. This system will produce more power than any other system on the market.
Our CES Racing Systems full 3.1/2" Turbo Twin Dump Pipe + 3.1/2" exhaust package for XR6 turbo vehicles picks up unbelievable power and is a great base (also) for those who aspire to go on to do further mods. down the track or for any racetrack application.
THE SYSTEM IS CAPABLE OF MAKING 558 ENGINE KWS. AVAILABLE FOR BOTH UTE AND SEDANS.
Full system 2 x pipework prices attached to choose from - mild steel pipework BASE COST + stainless steel pipework (upgrade) choice system. No power difference between the two choices only stainless will last the life of the vehicle. Mild steel has a shorter life span.
(Both choices still include a stainless resonator + polished s.s. muffler, twin tips, stainless special cat. converter) plus fitting inclusions nuts/bolts/gaskets * see attachments.
Front section only (starter pack) available. 3.1/2" Turbo Twin Dump Pipe + 3.1/2" high flow METAL SUBSTRATE core CUSTOMISED cat. converter (flanged) + pipework to reconnect to your rear standard system. Photo attached. (example shows coated item). Dyno sheet stats. available. Performance gains 29 kw @ the wheels pick up. Spools up earlier - brings on boost quicker (limited by stock system on car).
Edited by our06t
