  • Member For: 17y 9m 24d
Posted
now im not sure what the stock boost is, probably about 6psi, is it possible that a 'BF xr6 turbo' can go lower then stock boost??
  • It's not a MKI!
  • Member For: 18y 3m 19d
Posted
Yep, everytime your coasting or you back off the throttle, I'm pretty sure you'll go lower than stock boost. :msm::spoton:
But if you mean when your on boost and it's not making factory boost pressure there could be some problem.
Hang on. Pleae explain yourself better so we can have an idea what your talking about by 'is it possible that a 'BF xr6 turbo' can go lower then stock boost??'.
I'm guessing here and you might not have any problems at all.
Posted
nah no problems, with a boost controller u can turn the boost up and therefore makes more kw.
is it possible to turn the boost down below stock psi therefore generating less than 245kw
  • Mmmmm......BOOST
  • Member For: 19y 5m 10d
Posted
your best off using a flash tuner to set your boost levels and I guess you could lower it ,but why
Posted
was figuring if could lower it, it might be p plate friendly
  • Mmmmm......BOOST
Posted
a flash tune could lower it and you could also lower rev limit , are you talkin legal for a p plater or just safer
Posted
yeah legal for a P plater
  • Mmmmm......BOOST
Posted
I think you would need to convince an engineer as to the power to weight and then go through all the rego crap to get it passed (nsw )
and considering how easy it would be to return it to full power I don't think they would go for it
Posted
yeah im in vic, hmm. territory turbo would be nice besides the fact they are double the price :crossjerk:
I wish there were a way around it
  • It's not a MKI!
Posted
There is a way around it.
Buy an XR6 and when your old enough, or legal, buy a T.
