Birdman Member 3 Member For: 17y 10m 16d Posted 20/11/08 09:38 AM Posted 20/11/08 09:38 AM I have a BA MKII 2005 XR6 T 240kw not modified. Since june of this year I have encountered a Throttle Interruption problem that occurrs without warning and with no common reason. Cold running, after 1hr of normal running, on a freeway, in the back streets. The only one aspect I can think as being common is excellerating but not hard excelleration. Ford have replace the Throttle Position sensor on both sides Pedal and engine and as of last week replaced the engine management unit. All under warranty thank goodness!!! It is still doing it. My local dealer has now run out of ideas. They can see the error codes in the "Black Box" but can't isolate the cause. Has anyone else had this problem and are able to share the solution. I have also had a new gear box Auto as well in Jan of 08. You might think I have a lemon but I still love the car. Luckily all of this work has been under warranty.Any advice welcomeBirdman
davidald Me Legacy Donating Member 360 Member For: 19y 6m 8d Gender: Male Location: Adelaide Posted 20/11/08 10:01 AM Posted 20/11/08 10:01 AM Can u b more specific? Describe what u mean by throttle interuption problem.
Azzman460 Azzman Member 223 Member For: 18y 2m 14d Gender: Male Location: Melbourne Posted 20/11/08 08:57 PM Posted 20/11/08 08:57 PM Possibly a wiring problem?
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 19y 1m 17d Gender: Male Location: Perff, WA Posted 21/11/08 12:09 AM Posted 21/11/08 12:09 AM Holy crap, is there anything on the car that is the original!? can't believe they replaced the engine!!!as mentioned above, are you able to give us any further insight as to what exactly you mean y 'interruption'? ie: is it not holding boost? or is it surging? or is there a traction control light coming on?Dan
PURVIE Sexy Member Legacy Donating Member 524 Member For: 19y 9m 26d Gender: Male Location: Berwick, VIC Posted 21/11/08 12:28 AM Posted 21/11/08 12:28 AM Could be hitting boost cut??? Have you had your cat checked?
straughsberry Legacy Donating Member 1,846 Member For: 19y 1m 19d Gender: Male Location: Broady, Melbourne Posted 21/11/08 01:00 AM Posted 21/11/08 01:00 AM What codes are coming up in that "black box" of yours?
Birdman Member 3 Member For: 17y 10m 16d Posted 22/11/08 06:15 AM Author Posted 22/11/08 06:15 AM Thanks for the interest in my problemAccording to the Manual it is called Throttle (acceleration system) fault indicator.There is a little engine symbol that appears on the dash. At this point the engine shuts down and according to ford goes into a Guard Mode. I have no power at this point, (not much fun as you turn into oncomming traffic). It feels like the engine is running on two cylinders. To correct the problem, I turn the engine off and can restart immediatley and a way I go.As per my post I am at a loss to understand what the problem is and I don't thing the ford dealer has any ideas at this point. Any ideas welcome.Birdman
davidald Me Legacy Donating Member 360 Member For: 19y 6m 8d Gender: Male Location: Adelaide Posted 22/11/08 06:21 AM Posted 22/11/08 06:21 AM Methinks Ford needs to pull out the centre console and replace it or more likely send it to Melbourne for repairs. Its not your throttle but a computer problem. This can cause the guard mode to cut in and funnily enough give false codes.
Dillz Three pedals are better then two.. Legacy Donating Member 15,637 Member For: 19y 4m 11d Gender: Male Location: Melbourne Posted 22/11/08 06:22 AM Posted 22/11/08 06:22 AM I say start again, did you buy it off a dealer or private?
MaTTe Member 143 Member For: 17y 11m 5d Location: Perth Posted 22/11/08 06:44 AM Posted 22/11/08 06:44 AM My car was doing the same thing, but it was the TPS, once it was changed the problem was fixed..It's probably worth getting ford to try another TPS as it may have just been a bad batch, and you were lucky enough to get 2 duds..If it's not that, it'd have to be something to do with wiring if it's picking up a fault and the sensors are all functioning properly..Good luck with the diagnosis
