J3TXR6 Member 88 Member For: 16y 11m Gender: Male Location: Melbourne Posted 28/08/08 07:10 AM Share Posted 28/08/08 07:10 AM Hey all,I'm new to this website as I finally bought a 2003 BA XR6 turboI went to Rajab Performance to get it on the dyno and check out what the problem was...as soon as it was run...the problem was diagnosed...The coils packs were f**ked and the spark plugs havent been changed since the car was made...the car ran s**t at only 140 rwkw at 5 psi maxSo I got the coil packs changed and new spark plugs and got my injectors taken out and cleaned and it was done...The car got put back on the dyno and ran at 207.2 rwkw, the second run 217.5 rwkw and the final run it got 228.7 rwkw!!!!we were astonished as the car is stock as a rock and it pulled such power...I have uploaded a video of the car on the dyno check it out.... Link to comment https://www.fordxr6turbo.com/forum/topic/49131-power-output-kw/ Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 18d Gender: Male Location: Brisbane Posted 28/08/08 07:20 AM Share Posted 28/08/08 07:20 AM Is that stock? Link to comment https://www.fordxr6turbo.com/forum/topic/49131-power-output-kw/#findComment-724699 Share on other sites More sharing options...
J3TXR6 Member 88 Member For: 16y 11m Gender: Male Location: Melbourne Posted 28/08/08 07:25 AM Author Share Posted 28/08/08 07:25 AM my car is stock as a rock!!! the car was running real rough when it hit boost so then I replaced all the coil packs and stuff and now she's running in perfect form... Link to comment https://www.fordxr6turbo.com/forum/topic/49131-power-output-kw/#findComment-724702 Share on other sites More sharing options...
wados Member 617 Member For: 20y 8m 26d Gender: Male Location: brisbane Posted 28/08/08 07:29 AM Share Posted 28/08/08 07:29 AM (edited) pulling those sought of numbers I dont think its stock, maybe previous owner had a tune loaded in the car but 228 rwkw is alot of power for a stock xr.But hey either way you got some good numbers there Edited 28/08/08 07:31 AM by wados Link to comment https://www.fordxr6turbo.com/forum/topic/49131-power-output-kw/#findComment-724703 Share on other sites More sharing options...
J3TXR6 Member 88 Member For: 16y 11m Gender: Male Location: Melbourne Posted 28/08/08 07:39 AM Author Share Posted 28/08/08 07:39 AM the previous owner was a executive for a big company and this car was stock (thus why I bought it)alot of the people I have told dont believe me but its true...the clip shows it pulling the power...cant wait to remove the centre muffler and chuck a K & N air filter in it...I want to still use it for a daily so I'm going to slowly mod it stage by stage... Link to comment https://www.fordxr6turbo.com/forum/topic/49131-power-output-kw/#findComment-724708 Share on other sites More sharing options...
qikshift Member 518 Member For: 18y 7m 29d Gender: Male Location: Melbourne, Victoria Posted 28/08/08 07:54 AM Share Posted 28/08/08 07:54 AM perhaps that dyno read a lil high , enjoy it regardless mate Link to comment https://www.fordxr6turbo.com/forum/topic/49131-power-output-kw/#findComment-724713 Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 19y 3m 1d Gender: Male Location: Bentleigh, Vic, Australia Posted 29/08/08 06:15 AM Share Posted 29/08/08 06:15 AM Id say the dyno is a little high dude.I had the same thing in my BF.I had my first dyno run at my mechanics which made 220 odd on the first pull then second was 231kw.I organised a Dyno day on that same DYNO, I asked my mechanic to double check the dyno before the day and it made 207rwkw's which is more believable.Regardless, good power! Link to comment https://www.fordxr6turbo.com/forum/topic/49131-power-output-kw/#findComment-725219 Share on other sites More sharing options...
Guest Guests Posted 29/08/08 06:48 AM Share Posted 29/08/08 06:48 AM Sounds a bit like a happy dyno but who knows... Could be one of the early freaks How does she drive mate? Do you get much wheelspin in a straight line when getting up it?? Link to comment https://www.fordxr6turbo.com/forum/topic/49131-power-output-kw/#findComment-725230 Share on other sites More sharing options...
South Member 323 Member For: 18y 9m 19d Gender: Male Location: Perth Posted 29/08/08 07:08 AM Share Posted 29/08/08 07:08 AM Run it down the qtr and compare your times to others... Will then indicate the real power. Link to comment https://www.fordxr6turbo.com/forum/topic/49131-power-output-kw/#findComment-725247 Share on other sites More sharing options...
J3TXR6 Member 88 Member For: 16y 11m Gender: Male Location: Melbourne Posted 29/08/08 07:53 AM Author Share Posted 29/08/08 07:53 AM I'll be taking it down calder once it re-opens!!!the car drives real good...wheelspin once in top end off boost in 1st, chirps 2nd and 3rd...I'm real happy with it....planning to bring it to the next dyno day that this forum holds for XR6t's Link to comment https://www.fordxr6turbo.com/forum/topic/49131-power-output-kw/#findComment-725267 Share on other sites More sharing options...
