July 12, 200818 yr #1 Hey all, while driving last night quite hard. Lost power to the wheels, looked in the rear vision mirror and saw nothing but smoke. Looked at it this morning and when engaged in gear it's pumping fluid out of a hole at the front of the bell housing. Its a 4spd auto with 2800 stally. Any ideas?
July 13, 200818 yr #4 its definately leaking through the front seal so you will need to remove the box to fix that at a minimum so your best bet is remove the box and check the damage
July 13, 200818 yr #5 is it a hole as in one that shouldn't be there or a threaded hole that should have a bolt in it?
July 13, 200818 yr #6 Author anymore details mate ,have you had a good look at it yetna going to take it to mechanics tomorrow. Or thinking of gettin it down to autotech if they can fit it in. I really dont have that much knowledge on autos, but at a guess thinking possible seal or maybe busted the convetor???is it a hole as in one that shouldn't be there or a threaded hole that should have a bolt in it?Na its cast in the bell housing
July 18, 200818 yr #7 Author Well the converter said no more! Look on the bright side.... Get the trans beefed up and a bigger stally!!!
