  • Member For: 17y 7m 28d
Hi,
I have a BA XR6T 4spd auto with 320rwkw... 45,000km on it
I dont use it much but might sell the everyday driver and drive this car everyday...
Is 320rwkw too much power to drive everyday without blowing something to smithereens..
It has a custom tune done, all the good bits. Is it risky putting too many km on it as something may break? or is this a safe power output for everyday driving..
Do you think it will hold out for a good 100,000km?
  • Member For: 19y 1m 25d
I had 320 now have 380+.
The 380 is actually easier 'cos the 320 had a heap of torque down low (as requested by me) and the 380 is much more linear and predictable.
As said have respect for the loud pedal and you'll have no problems.
Im talking about commuting to and from work, normal driving cruising, regular servicing and the occassional flat stick acceleration.. As you would drive any car...
Is just cruising about in these high power XR's contruting to more than normal wear?
  • CNUTOX
  • Member For: 22y 5m 8d
My car has 106,000kms on it. It was modified after 20,000kms. Nothing except the auto hasx blown. And if you know me, you know I drive it hard whenever I can.
  • Member For: 18y 8m 14d
I drive same model, BA Series I XR6T with same power., never had an issue. As mentioned I service regularly and drive nice "most" of the time. I have 110,000 on the clock with the last 25 being fairly easy. Consdering the first 70-80 were quite hard, I can't complain. Treat it nice, you shouldn't have a problem.
  • Member For: 17y 10m 16d
treat it well and it will last age's dude
even with stock power if there driven hard you can wreck them pretty quickly
I might load one of the softer tunes in it...
But if you at the lights with say a FG XR6T, Ill be grasping for my capa box in the back seat trying to load up the higher performance tune.... by the time it loads up the Fg is gone...
  • NOT THERE!... THERE!
  • Member For: 17y 1m 22d
Yeah but then you can just bide your time 'til the NEXT set of lights :innocent:
