ENV-355 Member 8 Member For: 18y 4m 20d Posted 23/05/08 12:54 PM Author Posted 23/05/08 12:54 PM I would bet its the tune allowing the boost to come on.it came on at 3500 with the tune before it started playing up so its not that.
ENV-355 Member 8 Member For: 18y 4m 20d Posted 23/05/08 12:58 PM Author Posted 23/05/08 12:58 PM I have seen a wastegate flap, drop out of its sleve, and was open all the time, this sounds like the same thing to me, the reason you saw 15 psi, with no exhaust is even when the flap is open, these cars can over boost with no restriction, so I think you will find, a bent actuator rodor the flap is not covering the hole properly.or could have came off the actuator completely. DavidYeah im thinking this also but the cat was deffinatly causing it not to boost above 6 psi with the 10 psi tune in.The rods still on the turbo and it doesnt look bent so the flap might not be covering the hole? or the actuator itself could be stuffed. ill check tomorow when I take the dump pipe off.
ENV-355 Member 8 Member For: 18y 4m 20d Posted 24/05/08 04:40 AM Author Posted 24/05/08 04:40 AM just to rull out a few things we swapped over the coils, wastegate actuator solanoid, boost preasure sensor with some spares we had and replaced the spark plugs. Its still slow to come on boost so its a wastegate/actuator issue for sure. just waiting for the car to cool down and we'll take the dump pipe off and see what the wastegate flap is doing.
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 29d Gender: Male Location: SW Sydney Posted 24/05/08 04:45 AM Posted 24/05/08 04:45 AM being an 03, the actuator itself could be shagged, but keep us all informed mate...
ENV-355 Member 8 Member For: 18y 4m 20d Posted 24/05/08 08:09 AM Author Posted 24/05/08 08:09 AM problem found.The bush on the waste gate flap has broken and is hitting on the manifold and would let it the flap shut. Needs to be tig welded and should be all good. A blocked cat was also the problem.
our06t Mmmmm......BOOST Member 3,135 Member For: 19y 5m 8d Gender: Male Location: central coast Posted 26/05/08 03:17 AM Posted 26/05/08 03:17 AM good to see someone post the fix to their problem ,you get a lot of people come on saying they have one problem or another ,then never come back and tell anyone how it was fixed
XR06T Legacy Donating Member 4,146 Member For: 21y 3m 13d Gender: Male Posted 26/05/08 06:46 AM Posted 26/05/08 06:46 AM good to hear its fixed mate. musta been a loud drive with nothing connected after the dump pipe!!!!
ENV-355 Member 8 Member For: 18y 4m 20d Posted 27/05/08 08:12 AM Author Posted 27/05/08 08:12 AM good to hear its fixed mate. musta been a loud drive with nothing connected after the dump pipe!!!!yeah it was very loud....sounded like a truck! could be heard from ages away haha. scared the sh*t out some ppl and we had one guy driving behind us blocking his ears. lolThanks for all the input it helped alot.
