XF Falcon <put funny sh*t here> Member 3,365 Member For: 19y 10m 26d Gender: Male Location: Perth, NOR Posted 03/05/08 10:10 AM Posted 03/05/08 10:10 AM Much appreciated EZ2CME! Looking forward to seeing how much better it is.See if u can take before/after photos of the your rims with the rotors showing, I wouldn't mind seeing if the rotors appear to be bigger cos of the slots...etc too
EZ2CME Formerly XR6NA Member 3,512 Member For: 20y 10m 4d Gender: Male Location: Brisbane Posted 03/05/08 11:34 AM Posted 03/05/08 11:34 AM No problem will do, always have the camera with me when doing mods on the car.
XF Falcon <put funny sh*t here> Member 3,365 Member For: 19y 10m 26d Gender: Male Location: Perth, NOR Posted 15/05/08 07:45 AM Posted 15/05/08 07:45 AM (edited) Does anyone know, are the standard BF front callipers single or twin piston PBRs? Edited 15/05/08 07:49 AM by XF Falcon
XR06T Legacy Donating Member 4,146 Member For: 21y 3m 12d Gender: Male Posted 15/05/08 07:48 AM Posted 15/05/08 07:48 AM standard ba are twin piston, so the bf are definatly not single
XF Falcon <put funny sh*t here> Member 3,365 Member For: 19y 10m 26d Gender: Male Location: Perth, NOR Posted 15/05/08 07:54 AM Posted 15/05/08 07:54 AM Ok, reason why I'm asking is there are some RDA 355mm slotted rotors I'm thinking of getting, but apparently my callipers cant be used unless I get a bracket made up to raise the calliper a bit. The standard BF rotors are ~325mm so there's a bit of difference there.The shop said there's twin piston PBR callipers they provide with those rotors which will fit ("they look like your ones but are different") and I'm thinking are they actually different PBR ones to suit a larger rotor, or are they just going to provide a bracket or something too?
XR06T Legacy Donating Member 4,146 Member For: 21y 3m 12d Gender: Male Posted 15/05/08 07:59 AM Posted 15/05/08 07:59 AM I;d imagine they would provide a whole new caliper, and no brackets.it wouldn't be worth upgrading the caliper, and still needing a bracket. may as well stick with the current caliper if that's the case!
XF Falcon <put funny sh*t here> Member 3,365 Member For: 19y 10m 26d Gender: Male Location: Perth, NOR Posted 15/05/08 08:06 AM Posted 15/05/08 08:06 AM So the whole new calliper, with no braket is probably a more proper (safer?) solution to getting a bracket for my current calliper. Seems like a bit of a waste getting something the same, only cos it fits properly? its a lot of bloody money.having said that, im sure I could sell my current setup to someone with a BA looking to upgrade to bigger brakes?
RBSMATT New Member 18 Member For: 18y 5m 28d Gender: Male Posted 22/05/08 02:57 AM Posted 22/05/08 02:57 AM (edited) So the whole new calliper, with no braket is probably a more proper (safer?) solution to getting a bracket for my current calliper. Seems like a bit of a waste getting something the same, only cos it fits properly? its a lot of bloody money.having said that, im sure I could sell my current setup to someone with a BA looking to upgrade to bigger brakes?BF XR8 Upgrades to suit BA BF cars is becoming a more common upgrade and the rear option is what is on the Typhoons with the Brembo front.You can also upgrade these kits with the DBA 4000 series rotors and performance pads and braided lines.Fronts from $700322mm x 28mm slotted discsTwin piston calipers to suitBrake padsRears from $550328mm x 26mm vented and slotted rotorsSingle piston caliper to suit Brake pads Edited 22/05/08 03:09 AM by RBSMATT
